| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
| More information would be helpful, such as... Coolant through the tool Carbide, HSS, Indexable, Cemented ect... Drilling into solid or pre-drilling/boring shape This should get us started.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
| One trick I have used often, is that when I reach the depth I need, I dwell slightly and then FEED back away from the bottom before doing a rapid out. That stops the shock that could be there from backlash. This has proven itself many, many times to stop chipping/breaking my tools. |
| i would look at the straightness and center of your predrill also. you don't state a diameter on your tool but it sound pretty skinny. generally with my form tools i drop the feed during the last .100 of the hole(whenever you hit the drill point from your predrill) when the tool starts to engage on all its faces ex: .250 cbore .720 dp .230 cbore .760 dp .120 thru in 6061 feed to .720 @ .003 ipr feed to .850 @.0008 ipr dwell x.1 feed out .003 (no withdraw marks allowed also i do all my critical form work on my sub i don't run ground bar so the GB tolerances make it difficult to keep things from bell mouthing |
| Need Help!- Spot Drilling/Center Drilling Steel 55 HRC | JWB_Machining | General Metalwork Discussion | 7 | 03-11-2009 01:35 PM |
| Form 20 A EDM | ramigary | EDM Machines | 0 | 11-27-2008 02:31 PM |
| drilling and drilling cycles tutorial | wmorre | General Metalwork Discussion | 0 | 10-18-2006 06:30 PM |
| How to build a vac-form box? | DIALED/CHUCK | Parts for Radio Control Models | 5 | 10-12-2006 11:54 AM |
| CNC Router Kit Form | xtaffy | DIY-CNC Router Table Machines | 8 | 02-17-2005 03:01 PM |
