Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 06-14-2010, 12:04 PM
symn is on a distinguished road
Exclamation Citizen K16 VIIP
Hello ;
Yesterday the electricity was cut off.Now PS0224 alarm is coming when i try to close to main chuck .Need to set zero return again. We bought this machine second hand and there wasn't Operation Manuel book.so i dont know how to set machine zero point.
if anyone has the same machine , could you please scan needed page from Operation Manuel book and send me e-mail or write here ? ( makmuhabd@gmail.com)
Old 06-15-2010, 10:01 AM
g-code_junkie is on a distinguished road
zero return
Originally Posted by symn View Post
Hello ;
press maint then goto return select axis and press exe and uncomp.Power off then power on go back to return select axis and then press exe then cycle start.
Old 06-17-2010, 12:53 PM
i tried your suggestion , i could set zero point of all of the axis except A1 axis .When i tried to set zero point of A1 axis , machine gave some alarms. i controled servo motor on main spindle . it is damaged so we have to change it.
thank you g-code_junkie for your interest..
by the way new servo motor is almost 1.300 $ including shipment.
Need Help!- Citizen L20 humbertocnc2007 CNC Swiss Screw Machines 7 04-16-2010 06:55 AM
Need Help!- Citizen L20,L25 humbertocnc2007 CNC Swiss Screw Machines 6 02-18-2010 06:17 AM
Need Help!- CITIZEN E32 6T karantaba CNC Swiss Screw Machines 1 09-18-2009 01:55 PM
Need Help!- Citizen L25 appusivadas CNC Swiss Screw Machines 4 07-16-2009 08:51 AM
Looking at getting used Citizen L20 PoiToi CNC Swiss Screw Machines 5 06-03-2009 08:55 PM
