| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
| There are many things at work here. First, we do not know the base material and that is a big factor, that aside... Is the root radius of the tool properly sized, it may be too large? If you are using a "Full Form" insert, try a small root radius non-forming insert. in your G76 code vary the infeed angle, try a full 30° per side infeed. Is the tool on center? Is the thread very long? This should get you started, let us know how you make out.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
| im using a single point tool by thin bit it has a 29 deg. face with a .001 R heres a peice of my program maybe this will help us better M25 G97S1000M3 M11 G121 G0G40G99 M10 M200 M20 G0Z-.02 X.400 T200(TURN) M3S2800 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.038 X.0605Z.011F.0015 Z.315 G0X.5 M1 T400 S800M3 G0Z-.05T4 X.100 G76P060060Q0002R0000 G76X.0428Z.315R-.002P0080Q0002F.0137 G0X.5 M1 |
| Still no material,try this... Code: X.1 G4 U2.0 G76 P020040 Q.0015 R.0005 G76 X.0428 Z.315 R0 P.0089 Q.0030 F.0137
Not so much, though the 800RPM seems slow. How did the code suggested earlier work out i.e. even if it did not work, what happended?
| the code kept giving me improper g71-76 alarms i kind of blended our programs together with taking more depth of cut and i also split the length in to heres my program now. but now the back wont go in the gage the front is going fine its just a tool pressure issue i believe T200(TURN) M3S2800 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.012 X.0605Z.024F.0015 Z.150 G0X.5 M1 T400 S800M3 G0Z-.05T4 X.100 G76P060060Q0015R0005 G76X.0428Z.150R0P0080Q0020F.0137 G0X.5 M1 T200(TURN) M3S2800 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.012 X.0605Z.024F.0015 Z.315 G0X.5 M1 T400 S800M3 G0Z.150T4 X.100 G76P030060Q0015R0005 G76X.0428Z.315R0P0080Q0020F.0137 G0X.5 M1 |
| If you are able to you may have more success with thread rolling - i've done M1.6 many times in material like surgical steel and titanium for body jewellery - dies last for ages and rolled thread quality is far superior For thread rolls we normally use Habegger in Switzerland - not sure if they have a US agent http://www.habegger-sa.com/English/produits_en.htm Turn to effective thread size of 1.373 with a 15-20 deg lead and use sprung collet and G32 feed on at 95% pitch, then reverse spindle and G32 out at 100% pitch |
| Some controls can only support a few lead in angles. (the last 2 numbers in the P word in the first G76). I bet that's what the improper G76 alarm was about. My citizen will only take 0, 29, 30, 55, 60 and 80, for example. try using P010055 , this should not alarm out. Also, I agree that the s800 is much too slow. Looking at a program where i single point a 6-32 thread in 304, i run at S2800. Also, if you can go any faster on your turn, do that as well. 304 loves to work harden and if you don't take enough off fast enough, it turns impossibly hard real quick. I also just realized that your OD is .060". >_< try this, everyone else is doing it!! =P T200(TURN) M3S4000 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.012 X.0605Z.024F.0015 Z.150 G0X.5 M1 T400 S2800M3 G0Z.150T4 X.100 G76P020055Q0005R0005 G76X.0428Z.150P0005Q0020F.0137 G0X.5 M1 T200(TURN) M3S4000 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.012 X.0605Z.024F.0015 Z.315 G0X.5 M1 T400 S2800M3 G0Z-.05T4 X.100 G76P020055Q0005R0005 G76X.0428Z.315R-.004P0005Q0020F.0137 G0X.5 M1 FOr the g76 you will want to start at the same z and cut air for the first half of your thread, otherwise you will get a line where the 2 threads meet. let us know how it goes! Edit: Also, I agree 1000% with the suggestion of a thread roll. We have 2 of the Habegger units and they have paid for themselves over an over again. just be careful, it's no fun getting a stuck stud out of the rolls... I know from experience. >_> <_< We got outs from alouette Tool co: www.alouettetool.com or 585.388.12440 Last edited by PoiToi; 05-27-2010 at 05:55 PM. |
#10
| so now my thread tool is controlling everything on my thread heres my prog: now when i ran this my maj: .0628 min: .0502 pit:.0568 even though my major started out at .0604 T200(TURN) M3S4000 G0X.150Z-.020T2 G1Z0F.002 X-.010F.0015 X.03 X.0605Z.02F.0015 Z.1087 G0X.5 M1 T400 S2800M3 G0Z-.05T4 X.100 G76P020029Q0005R0005 G76X.0448Z.1087R0P0080Q0020F.0137 G0X.5 M1 T200(TURN) M3S3200 G0X.150Z-.020T2 G1Z.1087F.0015 X.06 Z.1874 G0X.5 M1 T400 S2800M3 G0Z-.05T4 X.100 G76P020029Q0005R0005 G76X.0448Z.1874R0P0080Q0020F.0137 G0X.5 T200(TURN) M3S3200 G0X.150Z-.020T2 G1Z.1874F.002 X.0605F.0015 Z.2661 G0X.5 M1 T400 S2800M3 G0Z-.05T4 X.100 G76P020029Q0005R0005 G76X.0448Z.2661R0P0080Q0020F.0137 G0X.5 M1 T200(TURN) M3S3200 G0X.150Z-.020T2 G1Z.2661F.0015 X.0605 Z.320 X.0649 Z.345 G0X.5 M1 T400 S2800M3 G0Z-.05T4 X.100 G76P020029Q0005R0005 G76X.0448Z.345R0P0080Q0020F.0137 G0X.5 M0 |
