Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 05-19-2010, 09:03 AM
dehoover is on a distinguished road
Tool Setter / Location
Has anyone looked into setting up a tool setter / loaction device in a Star Micronis SR20 J. I am trying to create a system with standard tooling as well as decreasing set up time.
Old 05-19-2010, 05:30 PM
glenthemann is on a distinguished road
I dont find it very time consuming at all to toss a tool in the machine..
TXXXX
G0X(bar dia)
put in tool, snug it down, jog x up, tighten down. good to go. A little different with the live and front/back working tools, but its pretty darn simple if you ask me, and the same amount of work is required for any preset tooling, you still have to MDI call the tool, move to a position etc.
Even with 'standard' and 'set' tooling, youre ALWAYS going to have to change offset values just like you do with regular old tools. Heck, even when you change an insert this is necessary.
for whats it worth, personally I dont think its worth the time, cost and energy put into preset tooling.
Old 05-20-2010, 05:24 AM
I would agree for the most part. However, when you have 30-40 of these machines along with thousands of part numbers and multiple employees of varying capabilities. I would think it would help reduce the set-up time of new jobs.
Old 05-31-2010, 01:58 PM
hacdlux is on a distinguished road
i use glens method on my stick tools
i do a little presetting with my id tooling.
i use shaft collars on the backs of the er holder, just push it in and tighten the set screws
http://www.mcmaster.com/#catalog/116/1152/=7bxveg
works awsome on drill bits
boring bars you just have to write down the x offset or g50 it in your program
Need Help!- Tool Setter Macro for M-V60C and Metrol Setter mitshack Mazak, Mitsubishi, Mazatrol 0 10-06-2008 08:39 AM
Need Help!- Tool setter macro for M-V60C and Metrol setter mitshack General CNC (Mill and Lathe) Control Software (NC) 0 10-06-2008 08:38 AM
Z Location - Where is the tool tip? brendanjerwin Benchtop Machines 14 04-13-2008 05:56 PM
Tool Setter GARY DAVIS Fadal 6 03-18-2008 07:44 PM
Tool change Location flyboypete Machines running Mach Software 5 02-10-2008 05:51 AM
