Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 04-21-2010, 11:17 PM
DCogswell is on a distinguished road
Miniature tube cutting
I'm trying to cut .042" tube stock to a length of 1.3". I'm trying to get by with just using a .032" groove tool to do the cut-off but, it's bending right now.
Any suggestions?
Old 04-22-2010, 04:48 AM
Gold Member
RomanLini is on a distinguished road
I'd grind it. Make a little end-stop fixture to set the length and cut with a drop wheel (even an angle grinder bolted to a pivot) with a 0.040" thin abrasive cut off wheel.
With the right set up you could cut multiple pieces at once to speed the job right up.
Otherwise you could use a Dremel with a 1" cut off abrasive wheel, you may even be able to attach that to the lathe.
Old 05-13-2010, 12:28 AM
hacdlux is on a distinguished road
761-x
761-x - high rake angle = low cutting force
iv used them to part .100 delren pins
ive got a couple if you have the holder
call me if you want to try one-
corey
Old 05-13-2010, 07:36 PM
PoiToi is on a distinguished road
Grind up a "tube grind" cutoff tool ...usually when you are cutting off you have the cutoff angle in one direction only(toward the part you are cutting off), a tube grind has an angle in both directions.
From above the tool edge will look like a fishtail, or a V (the two top points of the V are the leading edges of your tool).
I hope this makes sense and helps you out!
Old 06-23-2010, 07:21 AM
dookie2022 is on a distinguished road
Have you tried moving the cutting tool closer to the guide bush (.1-.5 mm gap)
Old 06-23-2010, 11:41 AM
g-code_junkie is on a distinguished road
small cutoff
Any suggestions?
I have used Max-bar in the past for small cutoff tools .02 to .025 wide.
http://www.maxbartool.com/cataolg/CutOff%20Combined.pdf
additional axis for tube cutting drafterman CNC Plasma and Waterjet Machines 4 06-21-2011 02:59 PM
Tube cutting software. jeeplogic General CAM Discussion 0 03-04-2010 11:23 AM
Newbie- Tube cutting; tin slots and tube ends marineboy CNC Plasma and Waterjet Machines 0 10-13-2009 04:03 PM
Need Help!- Laser with rotary for tube cutting PMF General Metal Working Machines 5 09-16-2009 12:57 PM
Cutting aluminium tube cnczoner General Metalwork Discussion 18 07-09-2004 05:06 PM
