Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 04-13-2010, 12:30 AM
gakor is on a distinguished road
How to program 1/8-27NPT on old FANUC 18T Screw Machine
Hello,
Would anyone know how to program external 1/8-27NPT thread on a FANUC 18T? What cycle to use and what format? I don't have a book available. Could anyone perhaps direct me to a source of some understandable instructions so I can read up?
Thanks,
Greg
Old 04-13-2010, 08:03 PM
PixMan is on a distinguished road
G76 cycle if your machine has it, is best as it offers the most control.
Do you have any manuals for the control to refer to? Some (rarely) are setup for single-line G76, most use the two-line format. I don't have the dimensions for a 1/8-27 NPT with me so I can't give specifics, but the format would be something like this:
G76P020060Q5R0
G76X.321Z.4P0200Q25R-014F.03704
I'd have to find my notes to give you specifics, but the first line P sets number of "spring passes" at final depth with the first pair of digits, thread end chamfer witht he middle pair, inckuded angle of thread for the 3rd pair. The first Q is the clamp value, meaning the smallest infeed increment. The first R is the finish allowance, meaning how much the final pass before spring passes will be.
In the 2nd G76, the X is the final diameter of the thread root, the Z is the length of thread, the P is the total "per side" height of the thread, the Q is the depth of 1st pass, the R is the the incremental (per side) amount of taper, the F is the lead of the thread.
hth
Old 04-14-2010, 01:29 AM
Thanks for the reply, PixMan.
It would be appreciated if you could occasionally check this thread, as I may need some more assistance. I needed to set up another job since I coulnd't figure out how to program NPT.
Although I could not resist to input the data into the machine. It gave me an alarm, but that's only because I cannot use a decimal point using the formula. I have to program using, for example, " .1"=1000" "
As soon as I converted the numbers, the alarm dissapeared. So my guess would be that your formula should work on this controller. I had no time to play with it, though, so I don't know for sure what problems I'm goign to get into. This is why I would like to appreciate it if you could check this thread incase something comes up.
I feel confident on boring mills and milling machines, but a screw machine with FANUC is definately a challenge.
Once again, thank you very much.
Looking for screw machine parts Shanghyd Want To Buy...Need help! 1 11-07-2009 04:21 PM
About screw machine billdaryy Product Announcements & Manufacturer News 1 12-24-2008 07:40 PM
what is a swiss screw machine ? laszlozoltan CNC Swiss Screw Machines 7 02-05-2008 04:04 PM
RFQ: Lathe or Screw Machine Job lerman Employment Opportunity 3 01-24-2006 04:50 PM
screw machine? pyroracing85 General Metalwork Discussion 9 01-26-2005 10:54 AM
