| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Can't expect something free will live up to their expectation. Check out NCmanager.
__________________ The best way to learn is trial error. |
| What kind of machine is it? Do you have milling interpolation? If yes, you could use G16 to engrave on the OD without using CAxis calls.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
| I use this to engrave on my Citizen machines. Though, if you're in the process of purchasing PartMaker(r), I would think they could supply you with code to do what you want in the interim, it's worth asking.
im going to try this on my next run for my c axis engraving part to try and reduce cycle time, it just depends on what your trying to engrave(custom stamp much cheaper than cam software.) from http://swissturning.blogspot.com/ Roll Stamping Another trick use of the Y-axis motion is to perform roll stamping using an ordinary straight stamp. There are several advantages to this method; first, for a simple, single character like a directional arrow a=or a single letter, there is no need to buy an expensive roll stamp an holder. Second, most gang type Swiss have limited clearance in which to accommodate a conventional roll stamp. By using a straight stamp and feeding it along the Y-axis the amount of “stick-out” in the X-axis is greatly reduced. Work Stamp The idea here is to synchronize the spindle rotation with the Y-axis feed rate. A simple way to accomplish this is to program the spindle in constant surface speed mode (G96). Then feed the Y-axis at the feet per minute feed rate. Since the only mode available is G98, inch per minute feed, we will have to convert feet per minute to inches per minute by multiplying by 12. So, if we rotate the spindle at 10 SFM by commanding: G96 M03 S10; We will need to feed the Y-axis at 120 IPM. Assuming a ½” diameter to be marked with ¼” square stamp, your program should look something like this: T0202; (Position the stamp mounted in position 2) G96 M03 S10; (Start the spindle clockwise at 10 SFM) G00 X0.55 Y0.6 Z0.3; (Rapid traverse the tool close to the part) X.48; (Position the tool so it will be 0.010” deep into the part during marking) G98 G01 Y-0.6 F120.0; (Feed the stamp along the Y-axis synchronous to the spindle rpm) G00 X1.18 T0; (Clear to safe index point and cancel offset) Make sure the Y-axis start and end points are far enough away from the work that the axis will have room to accelerate and decelerate while the stamp is not contacting the work. |
| Cam software for 4-5axis as well as swiss turning centers | glenthemann | General CAM Discussion | 7 | 01-12-2012 02:31 PM |
| Please advise: Swiss turned plastic parts. Appropriate applicaiton for swiss turn? | MadMax | CNC Swiss Screw Machines | 15 | 04-14-2011 11:33 AM |
| engraving on swiss type machine | maximusek | CNC Swiss Screw Machines | 6 | 05-02-2010 02:06 PM |
| Engraving software? | Rainman229 | General CAM Discussion | 1 | 01-03-2010 05:16 PM |
| Engraving software | Hack | Engraving Machines | 19 | 12-30-2007 08:33 AM |
