| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
I have a Tsgumai B32 swiss and need to thread a rather long length medical thread, and....here's the catch....I am currently unable to thread whirl it. The machine has the standard Fanuc 18i-T control. Can anyone tell me how to thread so far, say 1.5", pick up w/ sub, reset Z, but still pick up the thread pitch and continue threading? I'm not sure if I can do it in G92 or G32, and would I need to re-orient the C axis each time. Help appriciated. |
| I do not know your control, but in general, this can be done. You would use G32. Your starting Z for the subsequent thread sections will need to be a function of the original starting Z and the thread pitch. You will also need to traverse into the previous thread section to blend in the meeting points. This should get you started, good luck.
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
the bs32 has more stroke thannecessary unless were talking about a rediculously long thread (over 10") http://www.cnczone.com/forums/showthread.php?t=100378 if you need any more help i might be able to point you in the direction of some one in the know good luck |
The issue is not the length of the headstock stroke, but the length of the guidebushing land.
| it is all dependent on what the thread is,the l:d ratio, and the initial stock size |
| Need Help!- Long threading | wilsondg | CNC Swiss Screw Machines | 0 | 03-03-2010 06:12 AM |
| Need Help!- 1 metre long Internal Threading..Any ideas ?? | intelsingh | General Metalwork Discussion | 29 | 01-08-2010 11:58 PM |
| How long would it take to cut this? | david90 | Benchtop Machines | 13 | 04-19-2008 05:45 AM |
| How long does it take | CNCadmin | Steam Engines | 4 | 11-08-2006 09:45 PM |
| Not long now | CRFultz | DIY-CNC Router Table Machines | 9 | 01-11-2005 01:13 PM |
