Old 04-11-2005, 09:11 AM
Rivet head is on a distinguished road
Question eroding Wire EDM fixtures
I make fixtures for one of my customers that has a wire edm machine. The problem we're having is that the fixtures are slowly eroding away where the parts being cut touch the fixture. I'm using 17-4 Stainless steel and heat treating it to H900. Anybody know how to prevent this erosion???
Old 04-12-2005, 05:48 AM
kevh's Avatar
kevh is on a distinguished road
Cool
Hi rivet head
I have sodick A320 and it is eroding away gradually my expensive hirschmann tooling the reason for this i have been told is due to secondary sparking from charged particals in the tank. Possible cures are:
1 Keep filters regularly changed
2 Older machines tended not to have EF11 or equiv Reverse polarity
3 lumps of zinc in the tank which tend to get attacked first.
Out of interest what machine is the fixturing for ??
What kind of fixturing do you make?? Might be interested ??
Cheers kev
Old 04-12-2005, 06:11 AM
roysol is on a distinguished road
I will add to this any movement of the part in the fixture creates it's own gap which a spark can jump across.
Old 09-29-2005, 11:40 PM
Xterrian is on a distinguished road
Why not use a non conductive material?
Old 09-30-2005, 07:15 AM
That is a valid technique which would require grounding cables directly to the part in order to complete the circuit. Secondary grounding such as this can help mitigate the arcing problem, even without changing the fixture material. The stumbling block is often the configuration, size and shape of the parts and their relationship in the fixture, often do not lend themselves to this approach.
Regards,
Roy Solomon
Charmilles Robofil Wire Edm sundara Machine Problems, Solutions , Wireless DNC, serial port 8 05-07-2012 12:27 PM
4 Axis Wire EDM Application squarewave CamSoft Products 4 09-30-2008 10:18 AM
ONA Wire EDM Wilkerson CNC Plasma and Waterjet Machines 6 07-03-2007 05:48 AM
Bobcad wire EDM for foam onthemarc BobCad-Cam 6 07-18-2005 09:13 PM
Wire EDM show and tell Graham S CNC Plasma and Waterjet Machines 5 01-21-2005 03:17 AM
