  #25   Ban this user!
Old 10-03-2009, 09:42 PM
plain ol Bill is on a distinguished road
It works - but I have a question. The Hypertherm 1250 operators manual V1.0 on the fine cuts page list's cut height for stainless at .010. You might have an older version of the manual. These are nice and I am going to print and then have them laminated.
  #26   Ban this user!
Old 10-03-2009, 10:40 PM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
Plain Ol Bill,
I can redo it easily. I would like to have the most current info on these. Can you PM me or post the link to the latest version?
If you print them on a sheet of transparency paper (mirrored or inverted) and use a xyron machine to make them into a sticker and then "stick" it to a sheet of magnetic photo paper, then you can post them on your command center. I can add any color background to the image needed. BTW, what is the standard color for plasma?
I found the pics of the timascus knife! Archiving off site makes sense if you can remember that you did it.
ID:	90428   Click image for larger version
ID:	90429   Click image for larger version
www.metaltechus.com
  #27   Ban this user!
Old 10-04-2009, 07:44 AM
ajclay is on a distinguished road
You've got a lot of time in them. They look great! I'll do the same as Bill....
The only thing I would of done differently would of made them a .pdf and not a .jpg photo...
There is a free program called cute pdf:
http://www.cutepdf.com/products/cutepdf/Writer.asp
Small, simple little program that makes a .pdf out of any file. You choose it as a printer and it will make a .pdf and save it to the harddrive.
Good Job!
Aj
  #28   Ban this user!
Old 10-04-2009, 07:50 AM
WSS,
Is that a mistake in the manual on stainless? Cut height at .010?
I asked Bill that the other day and he didn't reply....
Manuals from Hypertherm on the internet has it as .010.... It really didn't work for me.
Aj
  #29   Ban this user!
Old 10-04-2009, 08:02 AM
WSS
I just downloaded the .pdf you made... Great.
As you can tell I'm half blind, but I don't see any information in the .pdf on the cut height measurement.
There's "peirce height is 1.50-2 times the cut height" but what's the cut height?
Sorry, I just don't see it. You might have to put a red arrow on it for me.
Thanks, Aj
  #30   Ban this user!
Old 10-04-2009, 08:11 AM
This is out the manual....
  #31   Ban this user!
Old 10-04-2009, 05:28 PM
WSS - you did a really nice job of coloring on that Timascus. The pool and eye pattern really shows up well. I like the inlay w/ the MOP in it too. All in all very well done!
  #32   Ban this user!
Old 10-04-2009, 05:32 PM
ajclay my manual is for the 1250 and on the fine cuts page at the top it lists ct height for stainless at .010. Cut well for me. I had called Hypertherm customer service for something else and questioned them about it. The manual they were using was not V1 and did not have that listed. He borrowed a current manual from someone else and it was in there. I questioned why so low and he could not answer me about it.
  #33   Ban this user!
Old 10-04-2009, 07:09 PM
WSS's Avatar
WSS WSS is offline
WOW, .010 is two hairs. That is close. I hope my THC is fast and accurate. I did not put any cut distance on these charts. I was not sure if it was standard. If some one can post it, I would happily add it.
Aj, the last link in post #23 is a four page PDF that includes all the charts in one pdf. I used Adobe Acrobat to generate the pdf. I assume it is compatible with all pdf readers. If it isn't, please let me know. I made the jpg file reasonably large for clear printing. When I was 25 it was no big deal, but I find the crisper the print is now the better.
WSS
www.metaltechus.com
  #34   Ban this user!
Old 10-04-2009, 09:03 PM
WSS's Avatar
WSS WSS is offline
Aj,
I checked out cutepdf.com, it is windows only. I don't have anything to run it on (my laptop for the DynaTorch is the only PC I have). I can also let my Mac generate a pdf through the os' print dialog. It may be more compatible.
WSS
www.metaltechus.com
  #35   Ban this user!
Old 10-04-2009, 11:34 PM
WSS's Avatar
WSS WSS is offline
let's revise
Originally Posted by Mongkol View Post
WSS,
I agree to add pierce height,pierce delay,cut height,air pressure for the kind of material.
Other?
Mongkol
Any info on air PSI, delays and cut heights? If we can compile this info, I will add it to the existing charts.
WSS
www.metaltechus.com
Looking for a tolerance chart.... RMW Mechanical Calculations/Engineering Design 6 05-07-2009 02:18 PM
comparator chart jas6142 Calibration & Measurement 0 02-06-2008 04:13 PM
chart on threads DONNYBRASS General Metalwork Discussion 7 12-12-2007 05:47 PM
Comparison Chart BJR Benchtop Machines 0 08-03-2007 04:04 PM
Comparison Chart BJR Benchtop Machines 0 08-03-2007 04:00 PM
