Old 09-06-2009, 09:03 AM
mls mls is offline
mls is on a distinguished road
what is the best thing in water table to stop rust
Hi I just am getting my table finished up I will try to get pics up here this week I am having some issues with the cut taper does not always seem to be the same really bad on .4 dia holes any suggestions.I would like to know what I should put in my water to avid rust and fungi.
Thanks Mike
Old 09-06-2009, 06:53 PM
plain ol Bill is on a distinguished road
Home made plasma quench
Hi Mike - here is a recipe I pulled off a previous post on the forum here. I have tried it and it works well. Materials available on Ebay.
PLASMA QUENCH RECIPE
Here's the recipe for home-made PlasmaQuench
1/4 pound of sodium nitrite powder ($15/pound)
1 teaspoon of Physan 20 ($8/8oz bottle)
1 oz Ultramarine blue food-grade dye ($5/oz.)
Mix well, treats 75 gallons of water.
Old 09-06-2009, 11:01 PM
mls mls is offline
Thanks plain ol bill
I saw that on fireo addictions post I will use this but I figured I would try to get a few oppinions.
Thanks Mike
Old 09-07-2009, 12:55 AM
Mongkol is on a distinguished road
Smile Ultramarine blue food-grade dye
Plain of Bill,
It sounds like Ultramarine blue is not soluble in the water. It is soluble in the oil. Is this correct?
Mongkol
Old 09-07-2009, 09:42 PM
Mongkol I'm not sure about the ultramarine blue. I used green liquid food coloring in mine. I wanted it to look like the "real" plasma quench.
Old 09-08-2009, 07:22 AM
jimcolt is on a distinguished road
For the cut quality concerns....you need to prvide a little more info!
1. What type and model plasma system
2. Height control system....accuracy, does it have initial (pierce ) height capability?
3. On what material and thickness are you cutting .4" dia holes with excess taper?
Jim Colt
Old 09-13-2009, 06:22 PM
mls mls is offline
Jim colt I have powermax 1000 my electronics are from Tom at candcnc with his torch hieght controller I am now sure how accurate our homemade table is what is the best way to check this and to set the backlash. The material is .375 steel.
Thanks Mike
Old 09-13-2009, 08:24 PM
I am not the motion control design expert.....just the plasma guy! I guess to check backlash I would somehow lock the drive motor shafts....place a dial indicator on the gantry and the torch carriage...then put pressure in each direction and record the dial indicator reading.
I'm not sure what you mean by "setting the backlash".
Jim
Old 09-17-2009, 09:14 PM
ajclay is on a distinguished road
Backlash is really the difference in movement in two directions. You have to take the backlash out first, So move some amount in positive x first. Then set a dial indiactor up and move positive x .5 ( assuming you have a 1 in travel indicator ) Confirm it moved .500, if it doesn't you have other problems. Now move the indicator on the other side and move back .5 in. If you have backlash it will read a shorther distance....
The key to checking backlash is to move in a direction to take it out. Then, the second move must be in the same direction. Third move, then move back to the starting place.
Aj
Water Table rust update WereWoof CNC Plasma and Waterjet Machines 12 08-29-2009 09:01 PM
Water Table Rust Questions... hotrodkid CNC Plasma and Waterjet Machines 41 10-24-2008 12:58 PM
Need Help!- Does anybody know what to mix in the water, on a water table? suzukirmz CNC Plasma and Waterjet Machines 8 06-22-2008 12:56 AM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 10:52 AM
plasma water pan rust inhibitor 40fordcoupe CNC Plasma and Waterjet Machines 18 07-01-2006 07:01 PM
