Old 09-01-2009, 09:16 AM
laserh20 is on a distinguished road
ab 9/230 control replacement
I'm considering replacing the Allen Bradley 9/230 control in our 2 1/2 axis waterjet with a p.c. based control. If anyone has done something similar, can you give me some direction:
What p.c. control to use?
What is the cost?
Do it in house or have an outside contractor complete work?
If it is done in house, how much time will it take?
Can I use the existing servo motors and drive cards?
Note, I am considering this because the parts (particularly the motherboard and monitor) are ridiculously expensive from ab (if you can get them at all).
Any help would be greatly appreciated.
Tim
Old 09-01-2009, 05:03 PM
Ron22 is on a distinguished road
Tim,
I have converted a few AB 9 series to Delta Tau NC.
There are alot of other NC controlers out there that could be used.
I would recamend you have an outside contractor complete thework. You could do it in house but do you have time to learn all about the controller used?
You should be able to reuse the same drives and motors. What drives are in the machine?
What brand of waterjet is it?
Ron
Replacement Parts? JMFabrications Haas Mills 4 02-27-2008 09:45 PM
Vmc 20 Inverter Replacement 340 Fadal 7 02-23-2007 04:37 PM
fan replacement on cnc kit krymis Industrial Hobbies (Support forum) 0 01-27-2007 09:45 AM
Replacement servos, not sure what I need.. yukonho Servo Motors and Drives 4 01-03-2005 05:56 PM
vdu replacement bbrreid General Electronics Discussion 3 09-02-2004 04:24 PM
