Old 08-23-2009, 09:00 PM
555e's Avatar
555e is on a distinguished road
Stepper motors binding up above 35% jog?
Just got my table up and moving ,using mach 3 in jog mode above 35% travel speed my steppers like Tye up or sound like there binding up, but below 35 they run great? am i trying to over speed them? any help would be great!
Old 08-23-2009, 09:17 PM
ger21's Avatar
What is the velocity set at, and what kind of drives are you using.
Old 08-23-2009, 09:39 PM
555e's Avatar
Drivers
I think it said 100 The drivers easycnc board with built in drives,thanks
Old 08-23-2009, 09:53 PM
ger21's Avatar
These?
http://www.easy-cnc.com/products.html
Old 08-23-2009, 11:13 PM
555e's Avatar
Yes the 3 axes
Old 08-23-2009, 11:31 PM
ger21's Avatar
It's probably resonance. If you have double shaft motors, you can make a damper that will eliminate the problem. I made one today and the improvement was night and day.
http://www.cnczone.com/forums/showth...639#post256639
stevespo is on a distinguished road
What are you using for a computer? I was seeing similar behavior with a slow (800MHz) computer and timing issues with the pulse generation (with Mach). Going to a 1.7GHz machine has made a world of difference.
Sounds like it could also could be mid-band resonance. People have had good luck with the dampers, or switching to a driver with resonance suppression.
Details on motors, screws, power supply, etc would be helpful.
Steve
Old 08-24-2009, 08:55 PM
555e's Avatar
I got it !
The problem was the acceleration was to high slowing it down did the trick it runs like a dream thanks for you guys help. I am using one shaft one motor and two rack pinion for my X using Mach Windows , i am messing with liniux Ubontu EMC
Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China Ling Product Announcements & Manufacturer News 2 07-12-2009 05:10 AM
x2 Stepper motors jan21 Benchtop Machines 2 05-05-2009 09:35 AM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 10:20 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 06:37 PM
New Stepper motors. alexccmeister Stepper Motors and Drives 4 04-08-2007 08:53 AM
