I would like to purchase good used hypertherm torch tips, part # 220007 60amp extended nozzle. These are used on the Powermax 1000. If you have a cnc plasma cutter and use this type of tip I would consider purchasing your old tips. Please email me direct at accufast@united.net or post on this forum. Thanks. Todd. |
| Good Luck. If your labor time is free and you dont mind reduced cut quality, you may succede. The machining on the nozzle hole size, roundness of the hole, and straightness of the walls is 4 decemal places. You will have to sell rebuilt nozzles fopr 2-3 times the price of new ones to break even. It isnt as easy as it looks. The type of copper used is hard (difficult) to machine. You would have a better chance of making a fortune by inventing Warp Drive or cheap Hydrogen! Good Luck
__________________ Alan Bradford www.plasmatechnologies.com |
| I don't know what kind of plasma tips you use but the copper isn't hard at all. I have cut hundreds of these and the cut quality reamains good enough to compensate for paying $5 or $6 to put another one in. I can use one tip more than once. As a small business I have no need to cut in the 4 decimal places. If I needed that close tolerance I wouldn't use normal plasma, I would look at HD plasma or other type of cutting altogether. If I can take off .01 to .015 off the tip to clean up the end of the damaged hole and get a second life out of a tip it was worth it. Since I have done this for 3 years I would say I have better results from reconditioned tips than I do original tips. The results are that I get more production out of the referb tips. I never planned on reselling any tips. I figure there are people out there with a similar machine and I would provde them with money that would be more than they would get more than scrap price for their copper. Besides if I can referb more than 3 per minute for one hour that makes it a good deal for me. You keep tossing out your consumables and wondering how you can make things more profitable for your company. If your labor time is free and you dont mind reduced cut quality, you may succede. The machining on the nozzle hole size, roundness of the hole, and straightness of the walls is 4 decemal places. You will have to sell rebuilt nozzles fopr 2-3 times the price of new ones to break even. It isnt as easy as it looks. The type of copper used is hard (difficult) to machine. You would have a better chance of making a fortune by inventing Warp Drive or cheap Hydrogen! |
| What tool do you use to reclaim the electrode? I have had very mixed results reclaiming electrodes. Some have been as good as new, and others have refused to fire. I got a machine tool guy to clean up some used electrodes, he did a great job and the profile was just the same as a new electrode but they refused to fire ![]() I also got the guy to accurately measure the hole diameter on a new finecut tip and a tip that had done a lot of work with a shadow graph machine. There was virtually no difference, in fact the new one was a fraction larger! ![]() Andy |
| Hopefully your electrodes have the Hafnium pellet in the end. If you shave too much off the end of the electrode the spring that retains the electrode against the inside of the tip will not make contact. I shave just the minimum to get the copper removed only. I usually change them out when there is first a misfire issue and have even put some in the drill and used a belt sander to clean a little copper off. Hypertherm recommends use until 1/32" of the Hafnium is gone. I usually clean up my tips up with a custom made collet in a lathe. I gently chuck up on the the electrode and turn it down on the lathe. Your misfire may be caused by the length of electrode and the spring being weak. Maybe you should try to see if you can replace your spring or pull it just a little to get some more length back. |
| If you are using a new electrode and nozzle.....and after use you are refacing them and making them usable again....then that tells me you are not using them to the end of their usable life the first time around! When the electrode is fully consumed (there are no "tips" on a Hypertherm plasma....nozzle and electrode are the parts) it will have .030" to .040" pit depth on the hafnium emmitter (insert).....if the front of the electrode is faced off to this depth....then the electrode is now too short to make adequate contact with the inner chamber of the nozzle....which will usually result in misfiring, but probably more important...will result in a higher arc voltage if it does fire and transfer to the plate....as the electrode is shorter, making the arc longer. Higher voltage (.040" longer arc will increase the arc voltage by approximately 10 volts)...increases the load on the power supply, shortening the duty cycle, as well as causes arc voltage based height control systems to move the torch closer to the plate....likely causing plate collisions as well as poor cut edge angularity. When a nozzle orifice is reconditioned...the only choice would be to drill a larger hole (unless somehow the hole is being re-welded with copper, then redrilled to the proper size)....a larger hole will decrease enrgy density of the plasma arc....which will reduce cut speeds and affect cut edge angularity. My guess is that the time spent reworking the consumables likely is more expensive than figuring out how to get the best life out of new consumables through clean air and proper pierce and cutting techniques. Jim Colt |
| In the attached photos I show the size of cut and what the torch parts looked like after they "mis-fired"(?). This was the original set on our PM1650 w/T100m torch. It made over 100 pierces on 3/4" AR plate and over 1800 inches of cut. Then I switched to the 1.25" cuts (no pierce, edge start) and did about 200 inches of cut before it gave out. I think it was the size of the cut that got it not the amount of cut time. Is this typical? Did I squeeze all the life out of the parts? Compared to oxy, I am happy with what I was able to do in both cut quality and maintenance. I have not done enough to make a cost comparison to oxy. Way to many variables at the moment. For instance I would not put aftermarket parts on a HP, but our Victor gear runs great (some manufacturers) on aftermarket. And sometimes you can find good deals on OE Victors consumables. Have not found any deals with HT parts yet. WSS
__________________ www.metaltechus.com |
#10
| Following advice on this forum I recently changed the Swirl Ring for a different part number My machine uses a machine torch and the Hypertherm manual recommends a 220327 swirl ring with finecut consumables. I used it like this for over a year before changing to a 120925 swirl ring as recommended. The difference in cut quality and consumable life is amazing! The cut quality was OK before but I used to have to clean parts up afterwards. With the different swirl ring fitted the cut quality is now good enough so I don't have to clean up the parts! ![]() The consumable life has also improved by at least 3 times! The only downside of using the 120925 swirl ring is that it uses about 3 times as much compressed air, my 200 litre 5.5hp three phase compressor is definitely earning its keep! ![]() Andy |
#11
If the electrode is .03" shorter and the spring that maintains the electrode/nozzle contact still places the hafnium in the same start location. The .03" must be a huge difference in the performance in the spring. It is my understanding that the compressed air flow moves the electrode back when the ignition takes place and is maintained throughout the cut. If the distance from part to electrode is maintained why would it need more power? I believe that the electrode never touches the "nozzle" once the flow is established.
| Hypertherm Consumables / Jim Colt | magma-joe | DynaTorch | 1 | 05-04-2009 02:58 PM |
| Hypertherm and "Fine Cut" consumables | alliance_metal | CNC Plasma and Waterjet Machines | 10 | 12-10-2008 03:48 PM |
| hypertherm consumables | Pure-Powder | CNC Plasma and Waterjet Machines | 14 | 06-03-2008 11:26 PM |
| consumables | cstroke | DynaTorch | 6 | 02-07-2008 10:20 AM |
| where to buy consumables | tuknrm | CNC Plasma and Waterjet Machines | 1 | 02-14-2007 02:04 PM |
