Old 07-27-2009, 11:32 PM
555e's Avatar
555e is on a distinguished road
THC For Mach who has the boards?
I would like to put THC on my new table who has them and what do i need ? Is it a 4th axes ?
Old 07-28-2009, 12:40 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
555e,
Contact Tom Caudle "Torchhead" he is a member here on the Zone.
http://www.candcnc.com/
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-28-2009, 11:00 PM
Torchhead is on a distinguished road
The MACH integrated THC logic lets you have a full Z axis for any type of cutting. By adding a cost effective DTHC module our Breakout/Interface product (MP3000) can turn the Z into a full interactive Digital Torch Height. You can switch from using Z for other 3 axis cutting, milling, drilling to DTHC in a simple profile change in MACH.
You can use your 4th axis to build a nifty rotary axis for pipe cutting! All you need is a full controlled XY and Z with separate motors and drives.
We have everything from board level products to full blown 5.5 axis stepper or servo controllers. You can buy in at any level of system.
TOM Caudle
www.CandCNC.com
Totally Modular CNC Electronics
Open Source Boards Available, Stepper Drivers and Break Out Boards pminmo Open Source Controller Boards 762 11-21-2011 11:51 PM
Need two boards cut freejac PCB milling 4 06-27-2009 09:14 PM
Flashcut to Mach conversion: boards? jtodd FlashCut CNC 1 04-03-2008 07:50 PM
Flashcut to Mach conversion: boards? jtodd Machines running Mach Software 0 03-25-2008 12:00 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 05:41 AM
