Old 06-02-2009, 11:28 AM
mrpeja is on a distinguished road
Torch dives into material
I'm cutting holes about 2" diameter using arc lead-in and -out. Every time at the end of cut, it seems to me torch touches material. Anti dive in Mach3 is ON.
I think I can avoid this when I disable THC300 function when I cut holes. And also enable again THC for other cuts. I reference the torch before every cut, so I don't need THC function when I cut holes.
How to do this?
mrpeja
Old 06-02-2009, 07:39 PM
Torchhead is on a distinguished road
anti dive in MACH is based on the actual speed and will not work if the speed does not slow down during the cut. It's primary design is to keep the torch from diving on sharp angles and at corners where motion feedrate drops below a set percentage of the normal feedrate.
There is a way to turn off the THC function in mach but you will need to have an M Code macro you can use in the G-code. You call the internal function in MACH to turn the THC logic off or on but they only way is to pass it the function call in the g-code.
The best way is to do the anti dive dynamically (based on the actual arc volts) rather than feedrate.
Our new MP3000-DTHC has that feature (we call it a "tip saver") because it keeps the torch from diving if you pass over a void or come back close to a lead-in. The operator can "tune" the value in the dynamic Cut Profile for each type of material they cut. The difference is that it does not disable the THC in MACH so if it still needs to raise the torch it can. Once the condition returns to normal the THC resumes normal up and down movement, It just keeps the tip from slamming down on the material.
TOM Caudle
www.CandCNC.com
Old 06-03-2009, 02:56 AM
Torch dives
Hi Tom,
Thanks for the reply.
Can you be more specific with the way to turn off the THC function in Mach. Please explain how to write an M Code macro I can use in the G-code.
mrpeja
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 05:23 PM
Need Help!- Different between hand torch& machine torch ltran2000 CNC Plasma and Waterjet Machines 7 03-02-2008 10:19 AM
valves for oxy/gas torch? redneck79 CNC Plasma and Waterjet Machines 1 10-11-2006 11:26 PM
Gas Torch Sanghera CNC Plasma and Waterjet Machines 40 05-20-2006 12:29 PM
