Old 05-13-2009, 10:24 AM
Gec Gec is offline
Gec is on a distinguished road
Hypertherm 1250 problem
Hi, I have 1250 mounted on CNC machine, it works for about 1,5 year ok but now I have problems with kerf angle, arc is unstable, sometimes it is on left side, sometimes on right side, angle can be 7-8 degrees. It is not always, I cut 6mm steel plate with 50Amps and fine cut nozzle, speed is 20mm/m, air is dry and clean, consumables are new. I changed machine torch but the problem is still there. Grounding clamp is on material with clean contact. In device is small pcb on front plate, there is some leds, when it cuts all green is illuminated with two red leds - start and afr, is this normal?
Old 05-13-2009, 12:21 PM
Med-Pac is on a distinguished road
We're running a 1000 hypertherm. It doesn't have the power that your 1650 does. I think that even with the extra power you have, 6mm material is to thick to cut with fine cut consumables. I'd have to use 60 amp consumables to cut 6mm, fine-cut wouldn't even be an option for us. Try slowing your feedrate down considerably, that might help you out. On the other hand, if you slow it down to much make sure you click your THC to manual so the torch doesn't dive into the material.
I'd also give the guys at Hypertherm a call, or look for Jim Colt on this website.
Hope that helps you,
Mike
Old 05-13-2009, 02:17 PM
Gec Gec is offline
Mike
Thanks for answering, I cut that material with fine cut nozzle before and it was perfect cut. I have very good THC - Burny Levitator and it work very well. I tryed to slow down feedrate, but no results.
Old 05-13-2009, 05:47 PM
millman52's Avatar
millman52 is on a distinguished road
Jim Colt is the Hypertherm expert here. I'm sure he will read your post next time he is logged on. I'm sure he can steer you in the right direction.
If it works.....Don't fix it!
Old 05-14-2009, 03:15 AM
Gec Gec is offline
I'm cutting now, arc is always on right side, I fix torch with angle on left side but arc goes on right, like there is some magnet. I tryed to fix work clamp on different places on table but always is arc with angle on right
Old 05-14-2009, 06:51 AM
Gec Gec is offline
I think that is fixed, problem was in table grounding
Old 05-14-2009, 07:12 AM
jimcolt is on a distinguished road
Hopefully you have solved the problem....poor grounding can certainly cause bad angularity issues. On my machine I have a ground cable attached to the main work clamp connection...that I attach directly to the sheet or plate that I am cutting. This eliminates issues with bad connections between the dirty slats and the plate. Grounding can be an issue once the slats get a lot of slag...or when you are cutting lightweight materials.
Jim Colt
HYPERTHERM PHC PROBLEM Pure-Powder CNC Plasma and Waterjet Machines 14 01-08-2010 05:03 PM
Just IN- New from AQE... GRINDMASTER 1250 Portable Downdraft Table 1250 CFM! DaveG@AQE Product Announcements & Manufacturer News 0 03-30-2009 10:55 AM
Newbie- hypertherm 1250 ec12348 Want To Buy...Need help! 6 02-19-2009 09:13 PM
Hypertherm 1250 with a T100M torch??? Short consumable life Brink_ CNC Plasma and Waterjet Machines 18 01-08-2009 11:28 AM
I am looking for New or USE Hypertherm Powermax 1250 Plasma Cutter newla Want To Buy...Need help! 0 12-22-2008 12:31 PM
