| Mach3 control over exsternal equipment? Hi, I´m planning a plasmacutter with an automatic sheet-loading/ unloading system. See animation --- > Can Mach3 be used to controll other things in a machine exept from the axis? (relay for pneumatics etc.). Is it possible to program this cycle in G code? |
| Yes, I don't see why it shouldn't be doable. Mach3 can run 6 axis of coordinated motion and control the I/O's for the solenoids etc. If two LPT-ports doesn't give you enough I/O then you expand with a MODBUS enabled PLC etc. The discrete outputs (and inputs) can easly be controlled by M-codes that you call from your G-code program or you can write an M-code that does the whole sheet loading cycle. Or you can program a PLC to do the sheetloading/unloading and just signal it from Mach - lots of different ways.... ;-) Cool animation by the way! /Henrik. |
| Control Software other then Mach3. | propmod | General CNC (Mill and Lathe) Control Software (NC) | 8 | 03-17-2009 01:36 PM |
| Need Help!- Control Mach3 with external VB.NET program | Adamj12b | Mach Software (ArtSoft software) | 0 | 12-30-2008 10:46 AM |
| Mach3 spindle control of Boxford 260 VMC | jwhitley | Benchtop Machines | 1 | 09-09-2008 01:21 PM |
| VSD-A Spindle control in MACH3? | mkuivamaki | Granite Devices | 8 | 09-08-2008 03:09 PM |
| BP CNC S1 Speed control with Mach3? | Jonne | Bridgeport and Hardinge Mills | 3 | 06-18-2007 03:31 PM |
