Old 05-04-2009, 07:10 PM
SNERLAND is on a distinguished road
OPTICAL READER
Is it possible to put an optical reader on my gantry for those brackets that are easy to draw by hand, but not easy to describe or draw with CAD? I would like to be able to scan the drawing and save it to the hard drive
Old 05-06-2009, 07:22 AM
millman52's Avatar
millman52 is on a distinguished road
As I understand it (I have never tried) there is relatively inexpensive software that allows you to snap a digital pic. Run it through the software & reduce/enlarge etc. Then create a file you can create code on.
Check & post your question further down the forums list. There is an entire section dedicated to software, CAD, CAM etc.
If it works.....Don't fix it!
Old 05-06-2009, 10:12 AM
I went down and looked, there are a lot of different forums. I'm not sure which one to post on.
Old 05-06-2009, 07:17 PM
millman52's Avatar
Here is a short thread on scanning an image or traced outline. Help - Scanned outline to part
I'm sure there are others. People who do art type work can probably help you best. I think Corel Draw version 12 & up is one software that allows you to do that sort of work. www.CandCNC.com sells or at least did sell a .dxf tool that helped clean up scanned images. Yoyu might even find some help here http://groups.yahoo.com/group/CandCNCSupport/
Old 05-08-2009, 07:42 PM
Torchhead is on a distinguished road
It's a LOT easier to learn to use the vector drawing tools in a package like CorelDraw, Inkscape or one of the low cost CAD programs. Scans and photos are bitmaps (thousands of tiny dots). You have to turn then into line drawings either by using auto-trace which is okay on simple B & W scans or photos of existing line art, or by hand tracing in the software. The auto trace leaves you with artifacts to clean up. You may think something you draw has nice complete lines but scan it and blow it up and you will be amazed at the roughness and breaks in the lines.
The mastery of the software side of CNC is every bit as important as being able to build and run the machine. It's somewhat like owning a car but pulling it with your trusty horse because learning to drive looks intimidating.
To build a giant scanner with a CNC machine would not be a trivial task.
TOM Caudle
www.CandCNC.com
Totally Modular CNC Electronics
Newbie- How to use behind the tape reader in fanuc 6M? Bolle_Ma Fanuc 10 03-10-2011 11:01 PM
Need Help!- Fanuc 0MC without tape reader emcomannen Fanuc 0 03-04-2008 05:44 PM
Tape reader paramaters... Was: Can't read from tape reader (11T) grweldon Fanuc 11 08-15-2007 04:06 PM
KMB1 Tape / Reader Sierra Products HURCO 1 05-07-2007 08:15 AM
Fanuc tape reader simoj Fanuc 0 09-13-2006 02:46 AM
