Old 04-26-2009, 01:56 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Need better torch height control?
I just bought a commercial Plasma table cutter in need of a new control. its an old Cybermation unit http://www.cimtec-inc.com/cfc7000.htm Its called an HVAC table only for sheet metal. I'd like to upgrade to cut 1/2" steel and AL sheets
The torch head clamps to a shoe with roller balls a couple inches away in all directions. The whole shoe is on a slide with an air cyclinder to retract. When running, you just drop the shoe on to the work and turn on the torch. height of the torch can be adjusted by unclamping and sliding, only when the torch is off.
In reading other threads I see Z axis ball screw and other devices for raise/lower of torch. What advantages to this over the simple setup I have? In other words do I need to upgrade here?
Karl
Old 04-26-2009, 04:23 PM
cowleym's Avatar
cowleym is on a distinguished road
Hi Karl
Keep it simple is my motto.
THC is fine, but generally you have to freeze the height when you slow to go round corners or the head will dive. Perhaps not nessesary if you have a super fast modern machine, but with a wire driven cyb it might be a bit of an issue. We have machines cuttting this thickness with ball transfer heads and have no issues, just keep your balls clean, perhaps spray them with anti-spatter spray.
Mike
Techserv
Old 04-27-2009, 08:29 AM
Alan Bradford is on a distinguished road
Hi Karl,
Mike is right about the CYB cable drive. It is too sloppy for precision cutting. Also the CYB controller does not have a Height Freeze output for a THC.
It waqs made for HVAC Duct cutting where +/- 1/8 inch was ok.
The roller ball head works fine, but will mark the AL plates if you are trying to keep them clean.
We have a Cybermation Retrofit Package available, but it retains the cable drive.
We can convert it to Rack & Pinion Drive and then it would be accurate for thicker cutting.
Where are you located?
info@plasmatechnologies.com
Alan Bradford
www.plasmatechnologies.com
Old 04-27-2009, 11:29 AM
Karl_T's Avatar
Originally Posted by Alan Bradford View Post
Hi Karl,
I'm replacing the control. If adding torch height control makes the machine better, I want to do it. What advantage does it give? (I'm thinking keep the shoe and air retract - add a device to raise/lower the torch within the shoe just a small amount)
Marking AL would not be an issue, no plans for decorative work.
I want to upgrade the cable to timing belt or rack and pinion. If you sell parts for upgrade, email me directly karltownsend@embarqmail.com
P.S. Any interest at all in the old cybermation control? It was running the day I bought the machine (last Friday)
Karl
Old 04-27-2009, 11:36 AM
Hi Karl,
I throw the old Cyb stuff in the dumpster when i do a retrofit.
I will send you information on what is involved in changing out the control and drives.
I havent done a CYB with Rack & Pinion drive but it isnt any diffrent than other machines.
Thanks,
Alan Bradford
Torch Height Control Rxe CNC Plasma and Waterjet Machines 7 04-07-2010 06:09 AM
DIY torch height control mjp CNC Plasma and Waterjet Machines 34 12-20-2009 02:57 AM
Torch Height Control luther Plasma, EDM and other similar machine Project Log 4 07-12-2007 03:51 PM
Torch Height Control / Capacitive Height Control ahlbebuck Open Source Controller Boards 0 11-27-2006 01:32 PM
How important is torch height control? mm0015 CNC Plasma and Waterjet Machines 4 08-06-2004 11:19 AM
