I don't know how close you are to Bothel, Washington, but Dan Mauch is a terrific supplier and has been involved with this DIY CNC movement from the beginning. His address is: Camtronics, inc. 18230 130th PL NE Bothell, WA 98011-3118 dmauch@camtronics-cnc.com I am not associated in any way, BTW. |
Hi Serhey, I just got mine up and running this past 2 weeks. I started last Feb. but with work and all I didn't get the table done till June I think, then my plasma machine took a crap on me so I couldn't afford a new one till last December. Well with a few interuptions I now finally have it up and running and I am working on learning all the little in's and out's there are to making succesfull burns on all thickness of plate. I purchased a new A-120 from Thermal Dynamics and so far think it will be a good machine. My only limitation will be the fact that it is wired to single phase power so my duty cycles will we affected somewhat on thicker material but shouldn't mean much on thin stuff, ( 3/8" and on down.) Anyway if I can help at all just email me and we can talk. My shop is just outside Snohomish Wa. which is about 2 to 3 hrs from Vancover I think. Good Luck Blake ( mobilefab@verizon.net ) |
| Thanks guys I am just getting started, reading posts and trying to learn. Could you advise me parts and electronic suppliers, please? How much and how long does it take to perform this kind of project? Thank for any information |
| I didn't keep exact track of all my costs but somewhere around $6000.00 US. I now use the table daily & is a money maker for my shop. The table paid for itself many times over in a year time frame. Not knowing anything about electronics I elected to go with www.candcnc.com electronics. I first thought it was a lot of money for the electronics, but it's a good product & it sure made life easier in that department. After building my table I could probably piece the electronics together & make it work. But I probably wouldn't bother. I'd most likely go with candcnc again. (no affiliation, just a satisfied customer) At more than one point in the build I wished I had bought at least a gantry kit from some one of the manufacturers out there. I just didn't want their operating system(s) their choice of motors, gearing etc. & still don't. For a small shop/home plasma table I don't think you can beat Mach3 & Sheetcam.
__________________ If it works.....Don't fix it! |
| At more than one point in the build I wished I had bought at least a gantry kit from some one of the manufacturers out there. What kind of kit did you mean, simple assemblies like a bearing - screw pair or it's complete kit for whole machine? |
| It takes loads of time to hand make (or 1 off) if you will all the small parts it takes to bolt/weld one of these tables together. If you don't have a small lathe & some kind of a milling machine you'll almost for certain have to find a machine shop or friend to do at least a small amount of work for you. Most things you will have to make can be done with a few normal home shop tools. A decent drill press will go a long way in cutting time out of the project. That way all or at least most of the sourcing of these parts comes in 1 package. When you decide to build from scratch You'll have to find & order or make yourself, everything you need from probably 20-30 different suppliers. A short list could include: Socket head cap screws 3MM, 4MM, 5MM 4-40 & 5-40 Then the drill bits & taps if needed from MSC, Enco, Mcmaster Carr etc.. Notched belt pulleys & belts Drive reduction(s) Rack & pinion or other, belt, sprocket chain etc. (drives) Echain to house all your wires hoses etc. Steel/Alum. for the fabrication. Limit switches Wire & cable The list can get long.
| What you will see in the VERY near future is "bare Bones" plasma or plasma/router tables with the mechanics done and ready for the Electronics/motors. The idea is to make it all just a plug together "kit" so you don't have to spend days and dollars trying to come up with all the right stuff. The market has shifted over the last year and the economy has accelerated the move to lower cost alternatives for CNC cutting without giving up important features and performance. For those with access to a machine shop the cheapest way is still to build your own BUT you will always be trading time for $$$. TOM CAUDLE www.CandCNC.com Totally Modular CNC Electronics |
#10
That's what I was trying to get across in words. I always wondered why someone wasn't doing this exact thing. Hopefully their web site will gain more detail as time progresses. I've scratch built several machines that are job specific to my work. Most of them for metal forming or bending of some sort. I pretty much knew what I was getting in for when I made the decision to build a burning table. Unless one has done similar projects before, It's pretty hard to imagine the 5 gallon bucket full of small parts that have to be made to build a table. Lots of the parts & brackets etc were much smaller than I deal with on a day by day basis. Drilling-Tapping holes for instance I do literally 1000s of 3/8" & up threaded holes most of them 3/4"- 1 1/4". It can be a bit hard to transition to the seemingly "easy" small holes. I do 1000s of feet of 1" & up shafting but rarely deal with 3/8" & 1/2" the gear reduction drives for a burning table require. I do not wish to be discouraging in any way. I just hate to see anyone throw out a fist full of money then realise it's much more of a project than they ever dreamed. One of my customers finally decided to retire a cantilever ESAB machine they are still using. They are now in the process of building a 8' X 20' gantry machine. I imagine at some point I'll be involved to some degree on that project. They have been quite impressed with the accuracy of parts I have been supplying them off my home built with your electronics.
#11
| Millman52, I asked myself that exact question after attending the Fabtec show in Chicago a year and a half ago. After looking at all the plasma tables available and what they were charging, I decided to do something about it. A year ago I started a company called Precision Plasma LLC and started building an unpainted 4' x 4' plasma table and gantry. I did not include the electronics, since other companies, like candcnc.com, specialize in that aspect. This allowed me to produce and sell the DIY kit for around $2.5K. Add the electronics, motors, and software, and you can build a 4' x 4' table for $4,000. Pictures can be seen at www.precisionplasmallc.com. Once I started selling the kit, the first thing I was asked is if I could sell a 4' x 8' kit. One week later, I had the first 4' x 8' unit built. The next day I was asked was if I would sell the 4' x 8' kit without the frame. Now my biggest seller is the 4' x 8' where I provide a print for a welded frame. The cost to build the 4' x 8' machine, including the cost of the frame material, is about $4.5K. (not factoring in shipping costs) The one thing you will notice about the table is that I direct drive the motors to the gear racks. This is typically not the best way to build a machine, but it works extremely well with the lightweight gantry I designed. I can achieve a rapid traverse of 1000ipm and an acceleration of 50in/sec/sec. This is done with 2.8A 276in-oz automation direct motors. I will be testing the 300in-oz candcnc.com motors shortly which should work even better. I am also designing a new low cost 5' x 10' gantry and rail kit of a different design which will cost around $5K with the gantry, electronics, and table material. Finally, I am working on an Industrial 8' x 20' kit which has a target price of $10K.(kit + electronics + material) Best Regards, Ron Chacich |
#12
| Thanks for tips, guys! I am kind of interested to build the machine by my own. So many frames designed already, I can choose something. But the electronics, is that too difficult to set up the electronics by own? I mean choose proper drives to servomotors, set up the software parameters etc. Do I have to be especially educated for that or it is enough just to read some manuals? |
| Tags |
| cnc plasma table |
| Looking for a CNC Plasma Table | coalstove | Plasma, EDM and other similar machine Project Log | 2 | 02-08-2009 07:52 PM |
| CNC Plasma Table - TPI | Degrom | CNC Plasma and Waterjet Machines | 7 | 11-14-2007 01:52 PM |
| Looking to buy a NEW Cnc plasma table | Perp | CNC Plasma and Waterjet Machines | 13 | 09-21-2006 10:50 AM |
| plasma table | welderman | CNC Plasma and Waterjet Machines | 2 | 04-01-2006 11:32 AM |
| cnc plasma table | chiliuno | CNC Plasma and Waterjet Machines | 7 | 04-04-2005 09:36 PM |
