Old 12-28-2008, 12:47 PM
Brink_ is on a distinguished road
Hypertherm 1250 with a T100M torch??? Short consumable life
I just got my first plasma table. It is set up with a Hypertherm 1250 machine but uses a T100M machine torch. Wondering if that's ok as the T80 is the proper torch for the 1250. Seems to cut but I am going through nozzles like crazy. Lucky to cut 1 piece per nozzle. I have been using the 100amp consumables that came with the torch. Should I be using 80 amp consumables because the 1250 is a smaller machine than the 1650 the T100 is made for? Or even lower amp consumables based on the thickness of steel I am cutting?
No torch height control so the pierce is close to the piece unfortunately. I'll be researching how to add a control. But the guy I got the machine from didn't have this much trouble with consumables....
Also should i be using shielded or non shielded consumables? I've heard both from various people.
Currently running for consumables:
nozzle: 220011
electrode: 220037
shield: 220047
Is it ok to be running the 100amp consumables for cutting mostly 1/4" and some 1/8" using my 1250?
Thanks in advance for the help.
Old 12-28-2008, 10:01 PM
Edwardo is on a distinguished road
Im not to sure about running a T100M on the 1250, hopefully Jim Colt will see your post and answer, i run the T80M on my 1250 and for cutting 1/8 i use fine cut consumables @ 40 amp and it just flies through it with THC and i read on here where someone is cuttng 1/4" with the same and having good luck with that, 100 amp seems kind of over kill and the 1250 is a 80 amp plasma cutter. With out THC i would suggest sheilded 40 to 60 amp nozzles to prevent spatter from sticking to the nozzle when piercing. Also make sure you have 90/120 psi dry clean air.
EDD
Old 12-30-2008, 06:00 PM
So I got a dryer. A new fancy filter. New 80 amp consumables.
And it's about the same.
after a couple cuts.
Cuts are better untill the tip goes of course.
Dryer and filter. 25 ft from the compressor like the instructions said...
Vid of a cut...
I watched the plasmas pressure gauge on the front panel and it seems to be getting enough air throughout the the cut.
Any help would be greatly appreciated guys. I killed 2 tips to cut out 6-8 tabs just now.
Old 12-30-2008, 06:54 PM
donnelson is on a distinguished road
i have a 1000 used it for quite a while then noticed it seemed to be going through a lot of ht e nozzles not so much the electrode but lots of the nozzles. I talked to a guy he said to take the outer shield off with the plasma turned off and measure with ohm meter from nozzle to table should not have continuity mine did down in the bottom of the case there is a diode block that goes bad they sent me the kit took it all apart in the very bottom of the case below the circuit board there it rests i could not tell much wrong with it but the guy says thats whats wrong so there we were he says to put plenty of the dielectric grease under it to help it cool done reassemble allparts loand behold it cut great and i could hardly believe it the parts kit i think was 80.00 works like it used to i hope this helps you out give hypertherm a call they helped me out and were quite nice about it
thanks donnelson
Old 12-31-2008, 06:47 AM
Big John T is on a distinguished road
Without some kind of Z to move the torch up to pierce height I would use drag tips and start every cut from an edge or you will blow out the nozzles. Correct cut height and speed are vital to consummable life. From the picture it looks like 1/4" plate are you using the cut charts for the 1250 to select your cut speed? Hopefully Jim Colt will chime in...
John
Old 12-31-2008, 11:06 AM
Yes it's 1/4. And I am using cut charts for the 1250 with Machine torch.
I guess I'm going to end up being the Z control. I will have to manually move it up and down for each cut with the switch located near the laptop mount.
Is it possible to add THC? This table uses a Windows 98 laptop running Supercam software.
Old 12-31-2008, 02:11 PM
Torchhead is on a distinguished road
Supercam is a Torchmate product. They sell a stand-alone THC unit with it's own lifter and electronics. You will have to download their catalog to get current pricing since it's no longer on the web page for the product.
The other alternative is a retrofit to a full 3 axis control and a controller that uses MACH3. It won't run on Windows 98 and laptops are not recommended. Laptops in general are a poor choice for a shop environment.
General rule of thumb is to "pierce high and cut low". If you have a Z that is controllable from the toolpath software you can easily setup a separate pierce height and cut height and even pierce delay. SheetCAM is a low cost package that offers integrated plasma tools and cutting. Even without a full blown THC you can at least control the piercing process more closely.
If you do elect to upgrade the table to full 3 axis control then you then open up the option to use the table for other processes ( like routing or drilling) that need toolpath control of Z.
TOM CAUDLE
www.CandCNC.com
Old 01-01-2009, 10:00 AM
PlasmaGuy's Avatar
PlasmaGuy is on a distinguished road
Brink,
My $02. cents worth is that you are going to need to invest in a refrigerated air drier. The photo you posted of the tip is exactly what I get when I use my 1650 on jobs that don't have refrigerated driers on-site.
What size receiver/tank are you running? Do you have an auto-drain valve?
Good luck and keep us posted.
Tom
Old 01-01-2009, 05:04 PM
Gec Gec is offline
Gec is on a distinguished road
So you have water table....there is no need to cut that thickness of material submerged in water, regulate water level 1/2" below material. You don't have THC, if nozzle is in water after air stops to flow then this is the reason of short consumable life. Nozzle must be always perfect dry. Other reason can be in bad contact of - pole and material, or that small switch on 1250 isn't in middle position for continuous cutting. On that video I can see that height cut isn't good, on proper hight you must see sparks in V. Just one cut on too small distance can destroy nozzle. Can you put here detailed picture of electrode, maybe this help us to diagnose the problem?
Old 01-01-2009, 05:13 PM
Seems a lot like my trouble is just the lack of THC. I need to be right there going up and down for lead in, lead out, and any changes in the height of the material.
Did this today with it. No problems. Still on 1 tip....
  #11   Ban this user!
Old 01-03-2009, 07:41 PM
xjdubber is on a distinguished road
where abouts are you located brink?
  #12   Ban this user!
Old 01-03-2009, 09:14 PM
Sylvan Lake Alberta....why do you ask?
Life is too short CNCRob CNCzone Club House 11 02-21-2009 09:56 PM
I am looking for New or USE Hypertherm Powermax 1250 Plasma Cutter newla Want To Buy...Need help! 0 12-22-2008 11:31 AM
Need Help!- Short consumable life Bigtoy302 CNC Plasma and Waterjet Machines 1 07-21-2008 11:25 PM
Optimizing consumable life, Improving cut quality Fiero Addiction CNC Plasma and Waterjet Machines 1 05-21-2008 10:14 AM
Hypertherm finecut consumable life bossfrog CNC Plasma and Waterjet Machines 9 10-25-2006 10:13 AM
