Old 10-11-2008, 03:23 AM
IeatSteel is on a distinguished road
thanks for helping me build my table guys !!
i just wanted to thank all you guys for your post and your great pics..i have used this site to build my plasma table, and have not had to post one ? about how to do it , you guys have got it covered....again thanks guys keep up the good work. cnczone kicks a$$!!! ill try to post pics...
Old 10-11-2008, 10:45 AM
DRL DRL is offline
DRL is on a distinguished road
Don't leave us hanging!!!! We need pictures and commentary so you can add to the knowledge base.
DRL
Old 10-19-2008, 11:59 PM
some pics
trying to get some pics up ..my computer is a pos....
ID:	68217   Click image for larger version
ID:	68271   Click image for larger version
Old 10-20-2008, 04:56 AM
TOTALLYRC is on a distinguished road
If that is a Xylotex board under the fan in the picture, I would move it out from sitting right on the heat sinks to spread the airflow over all 4 of the drivers or possibly 2 fan,s. If you are using only the first three drivers and are using the fourth to drive a forth axis in the future, bias the fan to the three that you will be using the most.
A fourth axis/rotary table most likely won't be pulling all the amps that the others will be pulling.
Other than that it looks good
Mike
Old 10-21-2008, 02:11 AM
yeah the fans could be moved back for sure...it was a temp mount..thinking about using two fans...programs are really short right now and i try to not leave the drives on while iam making changes...so i hope it will be ok for a sec....iam going to be adding some pics for you guys ...and you can tell mw what i need to change ..so for the machine works great ...it does what i need ..
ok a lil bit about my table, its a 4x4 with xylotex 4 axis drive board and power supply with 420 oz motors, is belt driven on both sides of the x axis and the y axis is belt driven as well...the z axis is threaded rod (going to upgrade to better rod , one day). the gantry is made of .120 wall 2x3 alum sq tubing with the guide rails being made of 2x3/8 and 1x1 cold rolled steel. the x axis rails are made of the same 2x3/8 colled rolled steel also. the table itself was made from 2x2 16 ga. mild steel for the legs (could have been lil thicker , just used what i had) the rest of the table is made of 2x3 channel iron.the whole table rides on the good ol skate bearings...i think they were like 7bec or something like that...well i hope this gives you a lil bit of info about my table. i will be putting pics up..but my computer is a pos so it might take a sec... any changes i need to make ..let me know but be nice this is my first one..
Old 10-22-2008, 01:14 AM
few more pics of the y axis and xaxis drive belt
ID:	68328   Click image for larger version
ID:	68329   Click image for larger version
ID:	68330   Click image for larger version
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
Helping a Highschool student with CNC lathes K.Nyman Wood Lathes / Mills 1 01-10-2008 09:20 AM
Hi guys, $50,000 - what table can this get me? Peon CNC Plasma and Waterjet Machines 12 08-21-2006 09:45 PM
