Old 10-09-2008, 07:12 PM
plain ol Bill is on a distinguished road
Shaft coupling supplier needed - help!
I am using a linear slide for my "Z" that has a 3/16" shaft. Then I am using a stepper w/ a 1/2" shaft in direct drive. I need to connect these two w/ a coupling and am not having any luck finding this combo. Tried MSC - Enco no luck - any suggestions folks??
Bill
Old 10-09-2008, 08:59 PM
kermit582 is on a distinguished road
I would try brent hubbard he has an e-bay store I think it is hubbard cnc. or mcmaster carr they carry almost anything you can dream of
Old 10-10-2008, 12:11 AM
tinman13 is on a distinguished road
Bill, The boys at Applied Industrial in Olympia can fix you up I'm sure...... Tell Kenny I sent you over and he can find anything you need.
I'll second the McMaster Carr site, I really think they have everything imaginable!
Steve
Old 10-14-2008, 10:48 PM
*Registered User*
JB Fab is on a distinguished road
McMaster - or with this being fairly small shaft you may try SSDCP
Old 10-15-2008, 04:48 PM
Thanks guys - found one.
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
Thinnest insulation foam (XPS) supplier needed salvaCNC CNC Wire Foam Cutter Machines 0 02-03-2008 11:00 PM
Greenhorn question...supplier needed Kozmonyet Stepper Motors and Drives 3 10-25-2007 12:58 AM
Looking for a supplier of interior splined shaft JerryFlyGuy Mechanical Calculations/Engineering Design 2 06-09-2006 02:29 PM
Small hose clamps - screw to shaft coupling? Chris D Mechanical Calculations/Engineering Design 5 03-20-2006 12:50 PM
