I'm new to the forums here and need some advise. I'm in the market for a Plamsa Cutter, Hypertherm is the brand I prefer. I'm looking at a used Powermax 900 or a new Powermax45 for twice the price. I plan on building a CNC table for the Hypermax in a Year or so. Both machines have the computer interface. Right now, I cut thin gauge metals regularly, but when I get the table going, I'll be cutting 3/8" mild steel on a weekly basis (not daily). We're on a tight budget, but don'y want to throw $ away when we should've saved up for something better. Thanks |
| The Powermax900 is a great machine...55 Amps output. If it has the RT60 upgraded torch...it is even better. The new Powermax 45 is the replacement for the Powermax600 (40 Amps)...the 45 puts out 45 Amps and cuts similar to the capability of the Powermax900 due to new technology. Consumable life on the 45 is also superior. Either way...you will have a great system! Jim |
| The mechanized rating for a Powermax45 is 3/8". If the cnc cutting machine has a torch height control with advanced features....like the ability to find the surface of the plate before every cut....then retract to a pierce height...the index quickly after the pierce to the cut height.....then it can pierce 1/2"....maybe even 5/8" with slighty reduced consumable life. I do 1/2" often...and 5/8" occasionally with my 45 on my PlasmaCam DHC2 machine. If you are hand cutting...the 45 is rated for 3/4"....with max severance of 1". Duty cycle is the other issue.....if you plan to do long duration cuts on 3/8" or 1/2" plate....on a hot day...you could exceed the duty cycle rating of the Powermax45.....another reason why it is machine cut rated at a thinner rating than for hand cutting...usually the operator will get tired with a hand torch long before the duty cycle is reached! If you were cutting 3 shifts a day...in an industrial high duty cycle application and were needing to cut 1/2" material...I would steer you towards a 130 amp, 100% duty cycle plasma system. Jim Colt |
| Hypertherm Powermax 1000 and Dyna4000 controller? | mgmetalworks | DynaCNC | 12 | Yesterday 06:52 AM |
| Hypertherm powermax 1000 and machine torch | Mongkol | CNC Plasma and Waterjet Machines | 3 | 06-22-2008 12:57 AM |
| 3/16" AL with Hypertherm Powermax 1000 | zeoncomp | CNC Plasma and Waterjet Machines | 7 | 01-16-2008 12:18 PM |
| Powermax II Help | Bryanpl | Stepper Motors and Drives | 14 | 02-21-2007 01:47 PM |
| Hypertherm Powermax G3 not so CNC ready? | Knut | CNC Plasma and Waterjet Machines | 2 | 09-26-2006 10:00 AM |
