Old 09-21-2008, 07:23 AM
johntm is on a distinguished road
Amperage vs. Thickness
While I understand that thicker plates require more amperage to cut (in general), is there an advantage to cutting with a higher amperage than the minimum required? I know 40A will cut 3/16 AL plate, but does the cut quality improve with 60A or even 80A?
Yep, you lose more material to the kerf at higher settings, but can you cut a cleaner edge with less nozzle damage at 80 vs. 40?
Old 09-21-2008, 11:32 AM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Yes you gain speed when you use higher amperage and are less likely to spread the heat. The same rule applies to laser cutting. The higher amperage and speed is used on sheetmetal so it doesnt start to walk and bend.
Compumotor a83-135 ... amperage jhowelb Stepper Motors and Drives 8 07-03-2008 10:30 AM
Reducing amperage? stdly General Electronics Discussion 17 02-22-2006 09:23 PM
What amperage can I expect? MrWild General Electronics Discussion 4 02-07-2006 10:48 PM
amperage rating miljnor Servo Motors and Drives 4 08-30-2005 03:53 PM
