| Possibly because the Z axis takes the weight of the torch asembly. If you used a rack you'd want to drive it with a stepper because an ordinary DC motor would be stalled under load. Rack and stepper should work well but screw studding is cheaper |
| And how does that work out for you? Would you say its just as good as a screw for speed and precision? Robin, Are you saying i can't use a servo for this? That doesn't seem right. The motors for z are always smaller the X&Y. |
![]() I'm always looking for different ways to do stuff. If you like rack and pinion, go for it, i was just mentioning the permanent load snag. |
Sirs, In the case of the small Pittman motor/gearbox, it is quite hard to backdrive it so freewheeling is not a problem. When using the stepper, I had a router as load with vee bearings on the slide; there was no tendency for it to coast downward. When the system is in operation, the stepper is energizer and does not coast downward. We used the Pittman motor/gearbox with auto torch height controls which we made on a number of our smaller machines. Regards, Jack C. Edit: One should also consider the machine geometry; sometimes a poor design exhibits excessive springiness, so acceleration or loading forces result in a far greater error than does the gearbox backlash. I have seen many amateur designs that are very poor in that they use long unsupported rails, rail systems such as pipes that were not designed to be straight within small tolerances. Some build carriages that are spindly, or the beams are too far from the bearings that support them. JCC Last edited by jcc3inc; 07-23-2008 at 08:24 AM. |
| Gear rack | n9nun1 | Want To Buy...Need help! | 2 | 04-08-2009 09:46 PM |
| Gear rack | rustamd | Solidworks | 9 | 08-06-2007 12:59 PM |
| Spur Gear / Gear Rack | ckrantz | Linear and Rotary Motion | 12 | 12-06-2006 11:06 PM |
| rack gear | mniadna | DIY-CNC Router Table Machines | 6 | 01-19-2005 09:06 AM |
| question on gear rack | wired | DIY-CNC Router Table Machines | 7 | 01-08-2005 01:37 PM |
