Old 07-19-2008, 07:05 PM
Fiero Addiction is on a distinguished road
Pierce delay and plunge rate settings.
I'm looking for some recommendations for pierce settings. I'm using Mach 3 and SheetCam with an Esab PCM875 (60 amp) with a hand torch on a homebuilt cutting table. I cut a lot of 3/8" steel and I destroy a lot of tips at start of cut. Sometimes I'm lucky to get 3-5 pierces out of a tip. On thinner materials that are easier to pierce I have much better results.
I'd like to know what settings others are using with good results, for 3/8" steel at 60 amps.
1)pierce height
2)pierce delay
3)ramp lead-in?
4)plunge rate
Jon
pierce delay in Mach 2 ? Redline CNC Plasma and Waterjet Machines 2 11-13-2011 07:58 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 06:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-22-2007 12:12 AM
Pierce Delay And Plunge Rate DISCONNECTED CNC Plasma and Waterjet Machines 3 01-29-2007 09:48 PM
peirce delay Redline Mach Plasma / Laser 1 09-01-2006 09:18 AM
