Old 07-12-2008, 12:44 PM
justlarry is on a distinguished road
quality of plasma cuts and amp settings
I am looking at the hypertherm powermax 1000 which puts out 60 amps max.
or the powermax 1250 which puts out 80 amps max. Also equivalent sized Thermal dynamic machines.
I want to spend as little as possible and only plan on cutting up to 3/8 inch steel.
The main question I have is can I get a decent quality cut edge in 3/8 steel using a machine torch on a cnc table with only 60 amps? Or do I need to go to 80 amps for best edge quality. Thanks Larry.
Old 07-12-2008, 06:18 PM
C.Michael is on a distinguished road
You have plenty of power at 60 amps to cut the 3/8..But the 1000 is good to 1/2..There is absoulutly no plans to cut anything thicker?? To have the 1250, it sure is a nice thing to know that you can do alot more than 3/8,even if you don't for a while..But there is one more thing to consider..The dryness of the air..I was having a bit of a problem with taper and cutting tips wearing out fast and lots of dross..I bought a harbor freight refrigerator dryer and also installed a motor guard dryer after the frig...unbeliavable the difference in cut quality..having that ultra dry air turned my machine into a freaking laser!!
Old 07-12-2008, 06:55 PM
Mongkol is on a distinguished road
Smile Plasma table
Hi Larry,
I advise hypertherm powermax 1000 with hand torch. It is compatible with CNC interface as well. It's more cheaper than machine torch and can cut up to 3/4".Pls see sample from this link My little project
Mongkol
Old 07-13-2008, 07:27 PM
jimcolt is on a distinguished road
Hypertherm just released a new product last week...it is called the Powermax45 and is rated at 3/8" for piercing and production cutting....it will do much thicker than that with edge starting.
Here is a link: https://www.hypertherm.com/powerfulplasma/
It is the latest generation torch design (both hand and mechanized quick connect torches available....with cnc interface standard.
Jim
Old 07-14-2008, 10:04 AM
lowpull is on a distinguished road
Originally Posted by Mongkol View Post
Hi Larry,
Mongkol
The hand and machine torch cut the same amount when mounted into a machine holder. The hand torch is only rated for thicker cuts when it is hand held and you can tilt the torch during pierces.
I have the powermax 1000 with machine torch and it has been cutting 1/2 inch plate very nicely.
Old 07-14-2008, 10:30 AM
Smile Plasma table
Hi Lowpull,
Thanks for your advice. I am building plasma table by hypertherm 1000 with hand torch. Is it difficult to connect the circuit to link hypertherm? I use Mach2.
Mongkol
Old 07-19-2008, 11:49 AM
Thumbs up
thanks for the help guys. I did notice the cutmaster 101 is about the same price and puts out 80 amps so i am looking at the thermal dynamics machine as well.
Old 07-23-2008, 04:03 AM
towertek's Avatar
towertek is on a distinguished road
Making a Hand Torch into a Machine Torch
Start by downloading the dealer service manual from the hypertherm library. Get the two schematics from the M60 torch reference manual and compare the two torches.
You will see that two leads need to be swapped on the M60 torch wiring harness in order to make it work.
1. The red wire in position 7 gets removed and put into position 8.
2. The violet wire in position 10 gets removed and put into position 9.
3. Tape the trigger closed on the hand torch.
4. If you havent done so already, set up a new Plasma Mach Profile to run plasma operations only.
5. Run Data cable from the Hypertherm data port to your selected dry relay (Hypertherm input).
6. Use your spindle on/off (M3 and M5) to fire the plasma up.
Old 07-23-2008, 04:15 AM
towertek's Avatar
Schematics for T60 torches
Here are the schematics.
ID:	63556   Click image for larger version
Poor quality and Wavy Plasma cuts (Pictures) Normsthename CNC Plasma and Waterjet Machines 23 05-11-2008 10:35 AM
frustration....plasma cuts off during cuts any ideas? gpnjuice CNC Plasma and Waterjet Machines 2 11-18-2007 07:45 PM
Rapid speed between cuts(plasma) C.Michael SheetCam 1 11-18-2007 02:03 AM
New plasma cutter ( Even cuts concrete ) ynneb CNC Plasma and Waterjet Machines 17 01-20-2007 02:54 PM
Plasma cut quality Apples CNC Plasma and Waterjet Machines 7 04-13-2004 10:18 AM
