Hello, I am having a problem with my Thermal Dynamics auto-cut 100 plasma cutter during the initial spark igniton. I get a spark, but do not get igniton. I have changed the consumables out many times, so I am confident this is not the issue. The problem also seems to be more prevalent with carbon steel than stainless. Any thoughts would be greatly appreciated. Thank you Tyson |
| This may be a silly question but have you checked the workclamp connections? Do you clamp to the workpiece itself or just the table? Is your shop air nice and dry? Did it ever work right? If so what has changed? TOM CAUDLE www.CandCNC.com |
| Our machine is a C&G systems aviator XLT plasma table with a Thermal Dynamics AUTO CUT 100 plasma system. I am concerned that moisture could be in the air line from the shop compressor. Right now we have a Norgren regulator with filter, what else do you reccomend to further reduce the air moisture. Thank You Tyson |
| hi steve! can your cutmaster 151 cut at 2mm in height of the piece to be cut? i have this machine but manual system and at 1mm is cutting intermittently do you know how to solve it? or what i'm doin wrong? the work cable is added from a clean area of the workpiece! thanks steve. carlos. |
| THC with HV/HF pilot arc?? | Fiero Addiction | CNC Plasma and Waterjet Machines | 25 | 10-09-2008 03:31 PM |
| Pilot Pro Ex ??? | gelaw | DIY-CNC Router Table Machines | 0 | 04-21-2008 11:58 PM |
| 3yr old Pilot | CNCadmin | Hobby Discussion | 0 | 03-03-2006 10:11 AM |
| Industrial engine ignition cut | itsme | General Electronics Discussion | 8 | 02-07-2006 06:41 PM |
| How to sheild a HF arc ignition cutter? | chinamill5 | CNC Plasma and Waterjet Machines | 2 | 12-04-2005 10:24 PM |
