  #13
Old 06-26-2008, 07:42 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
One of these may also be of interest as a Forklift alternative.
http://www.maybury.com/liftruck/Crow...e-stackers.htm
www.integratedmechanical.ca
  #14   Ban this user!
Old 06-26-2008, 08:02 AM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow Table Loading
Originally Posted by TT350 View Post
Any one have pic's?
This picture shows one table loading method. (Not mine)
  #15   Ban this user!
Old 06-26-2008, 08:28 AM
Big John T is on a distinguished road
It will be a fore hire shop and I'm not scared of
spending a little money but I would like to
see how people are handling there materiel
so I can see what will work best for me.
The engine hoist will get it out of the rack
and to the table but how would 1 guy get a
4x8 3/8 steel plate on the table with out killing
your machine or your self?
The problem you will have is getting the plate from vertical to horizontal without smashing things. A 3/8 4x8 plate weighs 500 lbs. The engine hoist is not the tool for doing that. If you have two hoists and clamp on plate clamps you can lower one while raising the other... If you need something that is portable construct an A frame with an electric hoist on it. Make it wide enough to span your table so when you have the sheet horizontal you can move it onto your machine then lower it to the machine. I would build a spreader beam to hang from the hoist then chains to the plate.
John
  #16   Ban this user!
Old 06-26-2008, 08:31 AM
The one on the bottom of this page is what I was trying to describe... except it don't need the fancy telescope...
FWIW, we bought a use 3 wheel electric forklift for $1500 it will turn in it's own radius and will lift 4000lbs...
John
  #17   Ban this user!
Old 06-26-2008, 09:45 AM
cam1 is on a distinguished road
Guess it depends on how you store the material. We store it on it's long edge in a simple rack with 2 inch sch#40 pipes as partitions. It takes up minimal space, and it's easy to get the stock in and out. The limitation with a forklift is getting the forks out....you will have to put some blocks underneath, and then use a pinch bar.How would you stack the plates in a rack with a forklift?
regards
Can't Fix Stupid
  #18   Ban this user!
Old 06-26-2008, 09:51 AM
regards
With a chain and a plate clamp and a fork to boom thingy.
http://www.lkgoodwin.com/more_info/l...g_clamps.shtml
John
Old 06-26-2008, 12:22 PM
DareBee's Avatar
To get the plate horizontal from the plate clamp set 1 edge on the floor and lower it onto some some lumber.
Remove the plate clamp.
Put your magnetic plate clamp in the middle of the plate and lift it in the horizontal position and set on the table.
Old 06-26-2008, 12:29 PM
DareBee's Avatar
Also, Gov't safety regulations must be considered.
The units depicted in the Avenue link I posted are engineer and/or CSA approved for the load limit listed. Here anyway, we can get huge fines for lifting equipment that is not approved (unless it is for personal use, but if it is at your business, good luck with that).
It costs me an average of $700 to have any lifting devices I design get a P. Eng. stamp. Records of yearly inspection by a competent person are also required.
4X4 Small Shop log Trail Logic Torchmate 8 03-24-2008 09:35 AM
Small shop 3 machines TT350 Tormach PCNC 4 02-14-2008 05:20 PM
where to get small quantity of material? pp-TG General Metalwork Discussion 3 12-08-2006 07:56 AM
Looking for small shop space - NE Mass or SE NH InspirationTool Mentors & Apprentice Locator 1 03-20-2006 06:27 AM
Would like to open small shop. speed33317 Haas Mills 14 06-30-2005 09:05 AM
