Old 06-01-2008, 11:35 PM
Steve Crum is on a distinguished road
Practical CNC table start up
Hope most of you saw my intro thread in the "club house". Well anyway I've been beating my head against the wall on this machine all weekend. Everything was set up 3 years ago then mothballed. Everything seems to work fine now except the loose nut trying to figure it out. I will be calling the company in the morning with a few questions like why when I execute the G28 command the head homes to the opposite corner of the table from where the limit switches should contact and are these switches the 'high limit' that is refered to in the book? Also if I use those limit switches and zero the table to machine zero all coordinate readings are - as in negative and all work would be performed from top right to lower left. Kinda backward from what I would consider normal.
Also I'm confused as to how the WinCnc program imports DXF files from the BobCad program and how conversion to G code is done. Bad Brad has done it with this system but I can't seem to figure it out. The file conversions will be a challenge for me as I also installed full internet access and a Mustek large format scanner on this system. Hopefully somebody can point me in the right direction on this. I was reminded tonight while screwing around with this, That I also have the full nesting program thru BobCad and Corel Draw 12 and Turbo Cad 7.1 are in the computer also..
ID:	60745   Click image for larger version
ID:	60746   Click image for larger version
ID:	60747   Click image for larger version
Old 06-03-2008, 07:54 PM
xjdubber is on a distinguished road
you need to change the direction of the steppers in wincnc
Practical CNC Clone cerealkiller2 CNC Plasma and Waterjet Machines 78 03-25-2010 09:25 PM
Practical CNC Hobbiest DIY-CNC Router Table Machines 8 10-21-2008 11:00 PM
Practical CNC?????? jeeplogic CNC Plasma and Waterjet Machines 9 10-16-2008 10:30 PM
Upgrade Practical CNC table cut more CNC Plasma and Waterjet Machines 12 11-02-2006 09:32 AM
Practical CNC, Any opinions? Brian P CNCzone Club House 2 02-17-2006 07:23 AM
