Old 06-01-2008, 11:09 AM
Pure-Powder is on a distinguished road
lead in/lead out
When ever I open a dxf file in lazycam using plasma button, I will go to check Lead ins and the mill climb is always high lighted, Could someone explain what mill climb is! Thanks Dennis
Old 06-02-2008, 12:08 AM
Torchhead is on a distinguished road
Climb cutting is defined as cutting in the same direction as the tool rotation. In milling it produces smoother cuts but requires a rigid machine to do it. In plasma climb would only refer to the cut direction (probably counterclockwise). Depending on the thickness of the material and the plasma machine you can vary the side of the cut that has the flare based on the direction you are cutting.
TOM CAUDLE
www.CandCNC.com
Old 06-02-2008, 09:02 PM
jcc3inc is on a distinguished road
Hello,
Climb milling would be done going CW around a piece. The mill cutter turns CW as viewed from above, so the cutting tool tries to pull itself along the path.
Typically with conventional swirl plasma, you travel CW around the outside, CCW on the inside of a ring, for example. This gives the squarer cut on the workpiece.
Regards,
Jack C.
Old 06-03-2008, 12:07 AM
So should the the Mill climb box be checked or not checked , will it make a difference on the cut! Thanks dennis
Old 06-03-2008, 09:21 AM
Pure-Powder,
You need to cause the path to be CW on the outside, CCW on the inside. Whatever your CAD CAM system needs to accomplish this.
Regards,
Jack C.
lead in-lead out on surface toolpath Tugiyana Mastercam 4 05-07-2007 06:16 AM
lead screw frankg521 Mechanical Calculations/Engineering Design 0 04-29-2007 03:38 PM
1 or 2 lead screws spoolin_20b DIY-CNC Router Table Machines 6 03-22-2007 05:50 PM
Unknown lead nut? slavkok Linear and Rotary Motion 2 12-05-2005 10:49 AM
Hot lead on a possible nice buy. Alan T. General Metal Working Machines 1 07-08-2004 11:07 PM
