| kerf issue! Is there a setting that I am missing when posting my G code out of Lazy cam for kerf offset! Watched the videos but didn't see anything about settings for Kerf, also what would the Kerf size be, I am running a Hypertherm 1000 with 40 amp Fine cut Consumables ... Any help on this would be great! Thanks Dennis |
| Hi: Don't know about Lazy cam, but kerf size is base on an initial guess, a trial cut of (say a square), and then a correction of the guess. Once you get it (after 1 or 2 trials), it only changes in proportion to the wear of the consumeable. We routinely achieve cut accuracies of +/- 1/16"over 8ft, using a fixed kerf size, which is more than good eneough for us. For artwork, it's an important setting especially to get the details. regards regards
__________________ ---------------- Can't Fix Stupid |
| Kerf comp Sir, Does your CNC controller have provision for kerf comp?? Some controllers do. Generally the kerf for plasma is small compared to a 1/2" end mill, for example. Regards, Jack C. |
| kerf I have a hyp. 1000 I run .03 for fine cut and 60 amp. shielded. set it to cut a line in the metal and stick a feeler gauge in the kerf to measure. I was told .06 for kerf but it did'nt work. I was out on the part. |
| Kerf We used to cut a small square, (having the speed, amps, height setup correctly) and measure the square size. Then you can make adjustments to correct the kerf. Regards, Jack C. Last edited by jcc3inc; 06-03-2008 at 09:18 AM. Reason: spelling error |
| How to detect Kerf Crossing ? [ THC PLASMA ] | MaXx | General Electronics Discussion | 1 | 12-02-2008 04:54 AM |
| Newbie- Kerf on Foamworks | GEFR | CNC Wire Foam Cutter Machines | 2 | 04-02-2008 03:56 AM |
| plasma kerf | sluggo | CNC Plasma and Waterjet Machines | 8 | 03-12-2007 06:53 PM |
| Help with selector switch wiring issue (***actually a motor issue***) | BEDFORD | Industrial Hobbies (Support forum) | 7 | 04-07-2006 04:19 PM |
