Old 05-08-2008, 11:04 AM
cweimaraner is on a distinguished road
CR Electronic HD Plasma - Winplasma
We have an 2000 CR Electronic HD Plasma table that works great, however we don't have the "Winplasma" software that originally came with this machine AND CR Electronic is out of business.
Does anybody have or know where I can get a copy of this software?
Jim
Old 05-10-2008, 03:53 PM
Torchhead is on a distinguished road
How is the unit controlled? Is it a PC running with a special card or just from the parallel port? I doubt they wrote the control software themselves. If it uses a serial port (or possibly a USB) it may be a Flashcut based unit and that software can be purchased easily. I have not heard of WINPlasma software but if it's another brand just repackaged (OEM) you should be able to find it.
If it works great, sounds like all you need is a manual(?)
TOM CAUDLE
www.CandCNC.com
Old 05-11-2008, 09:41 AM
It is controlled by a "Phoenix II" card made for CR electronics. It also has some sort of "CR Electronic" branded Hypertherm THC.
The problem is that it does NOT take standard ASCII files for input, therefore I simply can't just write a post-processor for our ProEngineer NC Sheetmetal, as I did for both our flashcut and wincnc software.
The files that it accepts end in a .PM1 and like I said, are of binary form, not ASCII. I do not have the manual for the machine, but there are many programs loaded into it from the previous owner as well as a standard parts library with allows you to cut many standard patterns. The original owners don't have the software anymore either!
The closest I could find to what is available is the Hypertherm's software, but they must have made this specifically for CR Electronic. I will give them a call and see if they can help.
Jim
Old 05-12-2008, 07:25 AM
jimcolt is on a distinguished road
I suggest contacting Cutting Systems Inc. in the Cleveland OH area.....they were involved in selling and servicing the CRE machines when they were active in N. America.
http://www.cuttingsystems.com/ Ask for Kevan or Kris Assadorian.....and they likely can steer you in the right direction.
Jim Colt
Old 05-27-2008, 01:37 PM
donaldooo is on a distinguished road
[QUOTE=cweimaraner;450698]
Hi, we recently bought an Cr electronic CNC plasmacutter, with the hypertherm HD3070. In about 2 weeks we have the machine installed on our location. The machine contains the original software/manuals, with cds included. So maybe I can help you. I understand that you only need the original CNC programming software?
Kind regards.
Donny
Old 05-27-2008, 01:59 PM
I have obtained a copy of the software, however it is protected by HASP/Dongle. So without the hardware Dongle, I'm SOL.
I have ordered a PlazPac 3 ssytem from candcnc.com to retrofit the whole machine and run it with MACH3.
Jim
Old 06-19-2008, 04:38 PM
JanD is on a distinguished road
CR electronic HD 6-20 rotatet work 34° hau wen reparirt thet.
Old 08-11-2008, 06:22 AM
FabrizioIT is on a distinguished road
Hi Donny,
the software is protected by dongle.
You need other license, you can ask to me.
Regrads Fabrizio.
Old 08-11-2008, 06:29 AM
Sorry Jim,
I arrived to late. I had the possibility to help you very fast.
Bye,
Fabrizio.
Old 01-26-2009, 07:57 PM
+zero is on a distinguished road
hi.
I have original winplasma 3 and 4.
I will install it on windowx xp but it give me error.
I can't install on windowx xp.
Anybody is capable?
  #11   Ban this user!
Old 01-27-2009, 03:24 AM
winplasma
Hi +Zero I have the possibility to help you and install on XP.
Which kind of plasma do you have?
Regards,
Fabrizio.
  #12   Ban this user!
Old 01-27-2009, 07:26 AM
Regards,
Fabrizio.
I have a 6000x2000 plasma hd3070 with phoenix 1.25.7 controller bought in year 2000 . I have only a plasma torch on machine.
I'm italian
Electronic Gear Box Atlas_Too General Electronics Discussion 1 11-11-2007 10:27 PM
Another Electronic Ploblem Smackre General Electronics Discussion 14 12-08-2006 11:17 PM
Electronic Parts vulcom1 General Electronics Discussion 9 02-27-2006 08:32 PM
I need an electronic guru.... turmite General Electronics Discussion 9 01-12-2005 03:01 PM
Electronic enclosure mikeschn DIY-CNC Router Table Machines 1 01-09-2004 01:53 PM
