  #25   Ban this user!
Old 03-19-2009, 03:14 PM
parasj is on a distinguished road
If its the flanges I think your talking about if you need Raw products or if we can provide you with anything check out our temp website:
http://www.palmerengg-int.350.com/
Cheers.
PJ
  #26   Ban this user!
Old 03-20-2009, 03:44 AM
FabrizioIT is on a distinguished road
Hello Lars,
yes I can help you.
Please let me know the serial number you see on your dongle key.
Thanks,
Fabrizio.
  #27   Ban this user!
Old 03-21-2009, 05:37 AM
grubbbster is on a distinguished road
Cheers.
PJ
Hi PJ.
Cheers for the link.
Had a look round your website but we do pretty much everything in-house....
Kirk
  #28   Ban this user!
Old 03-21-2009, 05:51 AM
Smile
We have had one of our plasmas running since wednesday.
I am very pleased with the results.
I have just got to find the best way in getting rid of dross/slag....Would a barrell with stones suffice?
Soon we will be making around 800 flanges a day so might need a decent size barrelling machine!?
We managed to get around 2500 pierces before had to change consumables which i thought was quite good...These were with genuine hypertherm consumables.
I had some thermacut consumable samples(non genuine hypertherm) delevered and tried these, but unfortunately they only managed around 20 pierces! Shame really as their prices are really keen.
http://thermacut.co.uk/
Kirk
  #29   Ban this user!
Old 03-21-2009, 07:03 AM
jimcolt is on a distinguished road
The Hypertherm HD3070's can cut the materials you are cutting ...virtually dross free. I would suggest having someone that is familiar with those systems (Esprit Automation would be a good choice as they have been working with Hypertherm products for many years) check them out. The HD3070 is a first generation HyDefinition plasma...and if one of them has the torch upgrade....which puts Hypertherm's newest HPR torch on these systems....you should have cut quality that is very close to laser capability.....and consumable parts should last approximately a full shift.
Do you have the Hypertherm operators manual? If not it can be downloaded from the Hypertherm website......follow the settings for gas pressures, flows, arc voltage, current, consumable part numbers, pierce height and cut speed exactly as outlined in the manual....and you will get excellent quality. I would suggest using the 70 Amp 0xygen cutting process on the materials you are cutting. Use genuine Hypertherm consumables....the aftermarket parts use a 1 piece conventional nozzle design, while the Hypertherm is a 2 piece vented nozzle.....which gives high energy density combined with long life.
Jim Colt, Hypertherm
  #30   Ban this user!
Old 03-21-2009, 02:13 PM
Thanks for the advice Jim.
We do have the upgraded hypertherm torch (HPR130.)Which we was using last week.
The outline of the flanges are fine....Its the bolt holes that seem to be worse affected with dross.
We have got a hypertherm manual,and i think we have done all the settings by the book....Will double check monday morning.
A rep from plascom is coming round next week,so will see if he can improve things....
Kirk
  #31   Ban this user!
Old 03-21-2009, 04:02 PM
Forgot to ask Jim....How many pierces/how long is a full shift?
"and consumable parts should last approximately a full shift".
  #32   Ban this user!
Old 03-14-2011, 09:53 AM
tglantek is on a distinguished road
i need help for my client
Originally Posted by FabrizioIT View Post
Hello Lars,
yes I can help you.
Thanks,
Fabrizio.
hello fabrizio,
i need help for my client.
he uses a old version of the plasma cr . It is the v2.4 but it is installed on PC dos system.
he tried to install it on Windows98 with the original instal, but the software doesn't work
the old install works on dos.. i don't understand why ??
my client would like use another soft like LANTEK . I can not read the code to drive the plasma table.
the soft writes files like *.tot and *.opt
can you help me...
i would like to know the file format and the transfert protocol if it is possible .
Great thanks and best regards.
  #33   Ban this user!
Old 03-14-2011, 12:07 PM
CR electronic plasma software
Hello,
I think your customer use a version of program called Plasma II ver plot 2.40;
this is a dos based program that runs even under Windows 98.
The output file of this program to drive plasma plotter machines are binary files, not like normal text files.
I can offer to you various solutions for your customer, even interfacing the CR electronic plasma machine with the current Cad-cam system the customer is using.
Please, feel free to contact me at fabrizioit@gmail.com
I'll show you the best solution in details.
Kind regards,
Fabrizio.
Originally Posted by tglantek View Post
hello fabrizio,
can you help me...
  #34   Ban this user!
Old 09-14-2011, 07:52 AM
Marco_68 is on a distinguished road
Winplasma - Wincam software CR electronic plasma
Hello,
I have a CR Electronic machine with HD3070.
We used computer with Winplasma/Wincam software but now it is fault!
We have the CD but we can't install the program in a new computer.
Is there someone cna help?
Regards,
Marco.
  #35   Ban this user!
Old 09-14-2011, 08:09 AM
Originally Posted by Marco_68 View Post
Hello,
Regards,
Marco.
Hello Marco,
the original program Winplasma (last versions called Wincam) for CR electronic machines use a protection key to give access.
The first release used an internal key, while the last versions swapped
to an external key.
If this key is not working you can't have access to the program.
I can investigate further if you give me more info about this, and may be
I can find the problem.
I created anyway some tools to help customers to change software
or use other ASCII files to drive CR electronic machines;
advise me to this email: fabrizioit@gmail.com
Waiting for your advise.
Kind regards,
Fabrizio.
  #36   Ban this user!
Old 05-17-2012, 10:50 AM
blastrac is on a distinguished road
Winplasma on Cr electronocs
We have a CR Electronics Plasma table that was purchased used. The model is 1999 and is using winplasma version 4.0. We need to update the PC and reinstall winplasma but do not have the key and would like to update the version.
Where do i go to talk with someone about my options with the software, I am desperatly trying to find a source for this information??
Electronic Gear Box Atlas_Too General Electronics Discussion 1 11-11-2007 09:27 PM
Another Electronic Ploblem Smackre General Electronics Discussion 14 12-08-2006 10:17 PM
Electronic Parts vulcom1 General Electronics Discussion 9 02-27-2006 07:32 PM
I need an electronic guru.... turmite General Electronics Discussion 9 01-12-2005 02:01 PM
Electronic enclosure mikeschn DIY-CNC Router Table Machines 1 01-09-2004 12:53 PM
