Old 05-05-2008, 07:39 PM
SIGNMAN is on a distinguished road
enroute 3 and ez-router
i am using enroute 3.2 to create g code
what machine profile would work best
with a www.ez-router.com machine
Old 05-05-2008, 09:23 PM
automizer's Avatar
automizer is on a distinguished road
its been a while since I have used enroute but I remember there being an engraving path that will put your tool path right on the vector line. If you know the width of your cut just use the standard offset toolpathing and use the cut width as your cutter diameter.
what model of ez-router do you have
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 05-05-2008, 09:33 PM
i have a 5x5 router table , when you go to machining it gives a list of machines with profiles, ez router is not in the list, can i use one of the listed machines or standard fanuc profile
Old 05-05-2008, 11:37 PM
automizer's Avatar
O i see sorry I miss understood your first question. Your looking to what post ti use, well a standard fanuc should work. But your best bet is some were in the books that came with it it should say the type of code it understands. I see on the website its run with Mach 3 so try the standard post. and try it
HAAS GR-408
Old 05-08-2008, 09:44 AM
jakeup20 is on a distinguished road
Signman, check your private messages.
Jacob
ayuda con EnRoute 3 alec00 Spanish CNCzone 24 04-01-2011 11:18 AM
EnRoute anyone? dcfuhr@yahoo.co General CAM Discussion 22 09-06-2008 05:10 PM
New in OZ teckcel-enroute mal mckenzie Australia, New Zealand Club house 6 07-03-2008 06:38 PM
Enroute 3 Users - I need help! JavaDog General CAM Discussion 3 07-03-2008 08:45 AM
Anyone using Enroute CNCadmin General CAM Discussion 0 05-28-2003 01:08 PM
