Old 05-05-2008, 03:01 PM
Big John T is on a distinguished road
Cutting First Parts
Here is a vid of my first parts cut with the machine torch.
I was cutting the support slats for my support table.
Can anyone comment on the cut if the sparks look normal. Hypertherm 1250 with drag tip on a floating head on 12 gauge sheet. hmmm, I was cutting at 125 IPM at 40 amps with a 40 amp tip and pressure in the center of the gauge... The orange puff of smoke was the 2x4 on top of the sawhorse... got a little too close.
Thanks for the help
John
Old 05-08-2008, 09:29 AM
No comments?
John
Old 05-09-2008, 02:42 AM
bekx is on a distinguished road
"They" are not intrested in cuting videos i presume , i uploded a video too and no responses either, i think it's great good job man .
Old 05-09-2008, 04:09 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Looks good.
I would only worry about the quality of the cut. Going straight, your arc follows so you can cut faster. You'll have to slow down around curves and corners especially in thicker material to avoid kerf or tail whip.
Old 05-09-2008, 09:17 AM
John
Old 05-09-2008, 09:20 AM
Originally Posted by mc-motorsports View Post
Looks good.
Thanks for the reply. Do you mean that the arc should angle back from the direction of cut?
John
Old 05-09-2008, 09:35 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Looks great to me. I don't quite have my plasma machine finished yet, but should in a couple months. Building an open garage to house my machine. I built it on a 5' x 10' utility trailer.
I just have a Chinese cutter that works okay by hand so far. I will see what happens when I try auto cutting. Most have said they won't work well and will burn through consumables. We'll see. I may have to get a Hypertherm myself.
Post some pics when you get the slats in that machine.
Lee
Old 05-09-2008, 10:18 AM
Hi Lee,
I'll try and get some pictures up this weekend. I've almost changed my mind on how I want to do my slats to incorporate a water table. As they say; hind sight is 20-20 when you can remember what you saw...
John
Old 05-14-2008, 09:45 AM
Here is a couple of pictures so far...
ID:	59562   Click image for larger version
ID:	59563   Click image for larger version
Old 05-14-2008, 11:32 AM
Fiero Addiction is on a distinguished road
Are you direct driving the belts? What size pulleys and motors? How fast can it run?
Jon
  #11   Ban this user!
Old 05-14-2008, 12:13 PM
The belts are fixed at the ends and come up around some turnaround bearings and over the drive pulley.
The one on the stepper is 12 tooth and the jack shaft is 72 tooth for a 6:1 ratio. Then the small pulley to the long belts is a 10 tooth with a 3/8" pitch so each revolution of the jack shaft moves the carriage 3.75" . This gives you .625" of movement for each revolution of the stepper. So this means that at 800 rpm on the stepper I go 500 IPM. This keeps me in the better rpm range.
How fast? it will go 500IPM and accelerate at 300 inches per second per second.
I used a nema 23 stepper from automationdirect STP-MTR-23079 with gecko 203v drives on 64 volt. Control is EMC2. I'm quite pleased with the results.
Here is a closer look at one of the Y axis carriages.
John
  #12   Ban this user!
Old 05-14-2008, 12:43 PM
JROM is on a distinguished road
Sorry to be such a duffus but would someone tell me how to start a thread. I got something I want to talk about.
thanks
Be carefull what you wish for, you might get it.
Holding Parts Down While Cutting Oldbill DIY-CNC Router Table Machines 11 01-11-2008 04:12 AM
Need help cutting 2.5/3d parts. bdesh123 G-Code Programing 5 04-17-2005 11:18 AM
cutting Parts from a plate... need some tips Bird_E General Metalwork Discussion 2 04-09-2005 11:40 PM
cutting cabinet parts Hack DIY-CNC Router Table Machines 5 04-01-2004 08:45 AM
info on cutting rc parts landart DIY-CNC Router Table Machines 0 01-18-2004 07:29 AM
