Old 04-28-2008, 04:41 AM
Grunge-Fut is on a distinguished road
My 4`x4` Table build
Hi
I have just started building a plasma table to take 1/2 a sheet in England thats 1250mm x 1250mm, I have designed it with 1350mm travel on X & Y and 140mm on Z, with 200mm hight between track and table.
the plan is to use a 25mm rail with a rack and pinnion drive on "Y" with a 424oz-in 23 size motor. On "X" Im going to use cam follower bearings on 75mm CRS runners with a twin rack and motors set up on the outside the same motors as Y, and a Merchant dice YZTR for "Z"
I have only made the bridge and mounts at the moment from 60x60x4mm box, I went for 4mm so I could get good tapped holes for all the brackets,
any comments or advise will be welcome.
sorry abouy the state of my workshop,
Steve
Old 04-30-2008, 09:24 AM
cjdavis618 is on a distinguished road
Looking good. Keep up the good work!
Old 05-01-2008, 08:04 AM
Thanks, I was starting to think I was on my own and no one was realy interested.
Steve
Old 05-02-2008, 11:28 AM
No, not at all. I like to think that your post has spurred them into building one of there own rather than posting.
Nevertheless, your work looks very good and clean. What tools are you working with to build it. It looks like your brackets were cut using cnc of some kind. Was it a mill?
Any plans drawn up yet for the complete design?
Old 05-02-2008, 11:57 AM
millman52's Avatar
millman52 is on a distinguished road
Have you started from a kit or all your own design? Progress looks good so far. Looks like you are doing a neat job with your workmanship.
If it works.....Don't fix it!
Old 05-02-2008, 03:51 PM
Hi Both
Thanks for the vote of confidence, I have drawn the whole thing on autocad myself no kit in fact I dont even have a plasma yet. I had a company on the south cost of england Laser all the brackets, I have a few tig welders a couple of migs a band saw, pillar drill just the usual tools, some of the drawings below hached drawings show bridge at either end to ensure motors clear legs
Steve
can some one tell me how to put the thumbnail photos in rather than the big ones im doing please
Steve
Old 05-02-2008, 06:32 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Try this:
1) "Go Advanced" button
2) "Manage Attachments" button (popup window will open)
3) "Browse" button
4) Find the photo on your PC (you can load up to 6 at a time)
5) "Upload" button (in the popup window)
You have to wait until the upload is finished, or it won't work, the more photos & the larger the photo, the longer it takes to upload.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 05-02-2008, 06:38 PM
Switcher's Avatar
Moderator
You can also go back & change your photos that you already posted to thumbnails, just make sure that you have them on your PC before you change any of them here.
If you don't have them on your PC, just download them from your post above, then re-post them as your thumbnails.
You can edit your post for a while after you submit them, I'm not sure how long the time frame is, I do know after a while you won't be able to edit your existing post
Old 05-02-2008, 06:42 PM
Thanks will try it and see what happens
Old 05-03-2008, 05:02 PM
millman52's Avatar
Your table is only 4' long so it will not be as much of a problem. Someone else might get use of my slat holder arrangement.
My table is 12' long, I wanted the holders to be easily replaceable in case of damage so I made the bolt in & in short sections like the picture below.
The slats don't sit in the bottom of the notches of the slat holders. They are slightly below the top edge of the 2 X 2 box tubing.
This way the slats sit directly on top of the box tube & have the best chance of all being the exact same height. Also the slat holders don't support the weight of the plate being cut, they only hold the slats upright.
Name:	CNC Slat Comb Drawing.jpg‎
ID:	58909   Click image for larger version
Name:	CNC Slat arrangement 001.jpg‎
ID:	58910   Click image for larger version
Name:	CNC Slat arrangement 005.jpg‎
  #11   Ban this user!
Old 05-03-2008, 05:49 PM
Hi Millman
I had to read that twice, but thats a real neat Idea, I had to have my slat suports cut in 6 bits not 3 as in drawing, believe it or not it was because of transport costs.
I wanted the slats to run away from me when I loaded table so the metal would slide with out risk of catching or "chattering" so my supports run across so your Idea will work well,
You seem to be using a simalar track and gear to me do you think you coul send me a picture of your gear rack mounting please
Steve
  #12   Ban this user!
Old 05-03-2008, 06:59 PM
millman52's Avatar
OK Looks like I have my pics loaded in reverse order of what I intended.
Last pic. bottom row: I first made a drilling jig & clamped it to the milling machine table, to hold the rack gear parallel with the milling table for through hole drilling. This allowed me to drill a series of evenly spaced holes the length of my milling machine table travel. then unclamp the rack gear & slide it to pick up my original hole pattern & continue down the length of the rack gear. My racks are in 6' sections.
First pic. bottom row: Shows drilling in progress. You can see in the pic I have already drilled a section of holes & indexed my drill back in the last drilled hole & redy to continue the process.
4th. pic. top row: Shows the racks bolted to strap iron. I drilled & threaded the strap iron to accept 5-40 socket head cap screws. Notice there is a row of drilled holes in the center of the strap to mount the assembly to the table.
3rd. pic top row: Shows the side rail of my machine frame with a row of holes drilled for & threaded 1/4"-28 NF. This is to bolt the rack/strap assembly to the machine frame.
2nd.pic. top row: Shows rack assembly bolted to the frame rail.
1st. pic. top row: Entire front side rail assembly including; Front table frame rail, CR strap bolted to the top of thr rail for outboard gantry linear rail, & the rack gear assembly bolted on.
I wanted all these parts bolted on so they would be adjustable for fine tuning as well as easily repairable if a rack becomes damaged or worn.
If you choose to do something similar I recomend mounting the rack gear to CR strap. I tried using HR strap on the first rack/strap assembly & found the inaccuracy of the hot finished (black) strap a bit hard to keep the bolt holes in good alignment.
If you have questions on any of this, feel free to ask questions.
Neil
Name:	CNC X Rack gears mounted 004.jpg‎
ID:	58925   Click image for larger version
Name:	CNC X Rack gears mounted 002.jpg‎
ID:	58926   Click image for larger version
Name:	CNC X Rack gears mounted 001.jpg‎
ID:	58927   Click image for larger version
Name:	CNC X Rack gears 002.jpg‎
Name:	CNC X rack gear drill 001.jpg‎
ID:	58929   Click image for larger version
Name:	CNC X rack gear drill 002.jpg‎
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 03:45 AM
Does anyone here build their own table saw? starCNC WoodWorking 10 02-10-2008 08:29 PM
nub wants to build cnc table monte55 CNC Plasma and Waterjet Machines 2 08-05-2006 07:39 PM
