  #13   Ban this user!
Old 01-07-2010, 02:45 PM
jimcolt is on a distinguished road
The Sensor PHC is a standalone plasma torch height control system that will operate with almost any combination of plasma and cnc cutting machine.....it would work fine with the Max200 plasma.
The Sensor THC is an integrated Torch Height Control with high accuracy....it will only operate with a Hypertherm CNC control, and most plasma systems. It operates as a separate axis on a Hypertherm CNC....and is designed to be accurate enough for high definition class plasma systems.
Jim
  #14   Ban this user!
Old 01-07-2010, 06:14 PM
Simon21 is on a distinguished road
jimm thanks, now I understand. We are in contact !
  #15   Ban this user!
Old 01-08-2010, 04:03 PM
Alan Bradford is on a distinguished road
Is the pantograph a machine that follows a metal template?
That is what we call them in the US.
If so, it may not be able to go fast enough for a plasma and THC.
If your cutting speed is slow then the height control will dive into the plate, or cut much closer than you want. Also the Kerf will be wider and your parts may be undersized.
Just something to watch out for.
If you can use it then the Sensor PHC will work nicely on the Max-200.
I have installed a few this way and they work great.
Good Luck,
Alan Bradford
www.plasmatechnologies.com
Hypertherm -vs- Miller ty1295 CNC Plasma and Waterjet Machines 6 01-05-2009 03:23 PM
Need Help!- Do I have to use Hypertherm for my cnc table? vorapotwong CNC Plasma and Waterjet Machines 0 02-24-2008 09:55 PM
Hypertherm or not ? zeoncomp CNC Plasma and Waterjet Machines 0 10-02-2007 10:40 PM
cnc hypertherm control? stanglou CNC Plasma and Waterjet Machines 1 03-20-2006 06:58 PM
THC 300 and hypertherm 1000 Don C CNC Plasma and Waterjet Machines 0 10-30-2005 05:33 PM
