Old 04-22-2008, 09:57 AM
*Registered User*
kirkln is on a distinguished road
Optical tracer
I just bought a Esab silhouette 500 w/ optical tracer and burny 2.5 control I can't get it to trace it starts and then loses the line I tried tracing just a piece of paper and it won't do it I painted the table w/ flat black paint it still doesen't work it keeps losing the line can someone help Thanks Kirk
Old 04-22-2008, 07:45 PM
xjdubber is on a distinguished road
I believe you need to have the trace printed in fat enough black line on white paper. I dont think that placing a white sheet on a black table will make it trace.
Old 04-23-2008, 05:46 AM
*Registered User*
I did that I read somewhere .035 wide it will not work it will work with the paper cutout if it is perfectly flat Thanks Kirk oh I cleaned the optic too
Old 04-23-2008, 07:25 PM
so did you get it going?
Old 04-24-2008, 10:05 AM
*Registered User*
No I went to store and got poster board paper it will trace a cutout but will not pickup a line I tried pencil, pen, marker, small marker and it will not even pickup the line seems to trace cutout pretty well though Thanks Kirk
Old 04-24-2008, 05:07 PM
tinman13 is on a distinguished road
White paper a little heaver than regular paper should work, I have found that computer paper after it is somewhat damp gets almost transparent. The eye won,t read it very well. It should see a line drawn with a sharpie pen.Some pens use a lot of reds in the dye and they don't see this very well. I did a lot of small parts cad drawn and printed on regular paper with a HP printer with a .035 wide line, worked well. (For bigger parts you just tape the sheets together! Crude but effective!)
Also clean the reflective surface behind the bulbs with alcohol, they need to be clean to reflect good.
One more thing, I found after several years the bulbs seemed to get dimmer, I replaced them and it made a big difference.
Hope this helps, Steve
Old 04-24-2008, 05:56 PM
*Registered User*
Thanks for the tips I Will try them Kirk
Old 04-24-2008, 07:45 PM
yep you need to print with a laser printer preferably
Old 04-25-2008, 08:31 AM
*Registered User*
I'm sure right. we do custom fab and repair work I was hoping to be able to hand draw something and burn it out for repair work Thanks Kirk
Linatrol tracer set up on Koike Plasma arlenw CNC Plasma and Waterjet Machines 28 08-16-2011 11:43 AM
Gorton Tracer Mill Retrofit Fred M Vertical Mill, Lathe Project Log 7 04-24-2011 08:05 PM
My New Optical Toy Micro Rotors Benchtop Machines 58 03-01-2008 10:45 AM
Tree tracer mill choppersprocket Tree 11 07-11-2007 01:37 PM
optical tracer to cnc conversion? tinman13 CNC Plasma and Waterjet Machines 2 03-04-2006 11:44 PM
