  #25   Ban this user!
Old 10-09-2008, 11:57 AM
matttargett4 is on a distinguished road
yeh that would be good
hi john,
im interested to know how it works, ive seen stuff on the floating head for initial height sensing but not wothout thc before, what kind of thicknesses are you cutting? are you on water? the opinion everyone seems to have is that thin sheets warp more but thc is good for all thicknesses but im interested to hear you are running without, guess it makes more difference on large pieces where the initial height sensing doesnt get a chance to run very often?
how then does this work with mach? i guess i just need the correct post proccessor for sheetcam and configure my inputs correctly for mach to get it to lower the z until one pin goes high then raise a set distance?
thanks alot
matt
  #26   Ban this user!
Old 10-09-2008, 02:31 PM
Big John T is on a distinguished road
Originally Posted by matttargett4 View Post
hi john,
I cut from 14 gauge up to 1/2" normally. I don't have any problem with warping on thinner material, YMMV. I have a water table and it is 3" below the material so it has no affect on the material.
thanks alot
matt
I don't have a clue about mack. All I know about it is I don't use it...
Here is my floating head
My Pilot Pro Ex Extended xmac DIY-CNC Router Table Machines 13 01-10-2012 07:32 PM
Newbie- Has anyone built the Pilot Pro or used one. pootsnicker DIY-CNC Router Table Machines 4 02-05-2008 09:05 PM
Oxy Acetylene gas saver - pilot light zcases Welding, Brazing, Soldering, Sealing 8 02-25-2007 10:31 AM
Pilot CNC woodworker2 Commercial CNC Wood Routers 0 03-09-2006 01:21 AM
3yr old Pilot CNCadmin Hobby Discussion 0 03-03-2006 09:11 AM
