Old 04-15-2008, 11:38 PM
john86126 is on a distinguished road
miller plasma
i have a miller 125c that i am going to use to make a cnc plasma to cut sheet metal and have 2 questions
1. whats the smallest relay i can get away with using a 10 amp is the biggest i can find for my mechtronic board will this work
2. if i cut sheet metal sheets 3feet x 3 feet how much will it warp as i dont want to buy a thc yet and suggestions
Old 04-16-2008, 11:12 PM
xjdubber is on a distinguished road
1. you only need a very small relay trace back the wires from the torch handle and switch those.
2. Make a floating head that will hold the metal down. Easiest way to do is with a pneumatic cylinder and some roller balls in round shaped disc to roll over the material while the cylinder pushes down only lightly
Old 04-19-2008, 03:22 AM
bekx is on a distinguished road
i find the machine allmost useless without a thc,
i got good result on 1mm thick steel sheet, and unusable on 0.8mm stainless.
but the thc is not only for warping, u will get more control on the pierce/cut height, resulting in better cuts and longer consumable life, i will tell you more when my thc arives ...
Old 04-19-2008, 09:43 AM
Big John T is on a distinguished road
If you use a floating head with the drag tip you will be fine.
John
Miller 180 syc wave tig larry53 Welding, Brazing, Soldering, Sealing 0 02-07-2008 10:02 PM
Miller tig kenlambert Welding, Brazing, Soldering, Sealing 2 02-28-2007 06:04 PM
Miller Robotic Welding Arm conv to Plasma CNC robo_plasma CNC Plasma and Waterjet Machines 2 01-08-2007 08:22 AM
Miller Tig larry53 Welding, Brazing, Soldering, Sealing 20 04-24-2006 04:49 PM
Miller spectrum 625 turbo71vw CNC Plasma and Waterjet Machines 2 04-13-2006 09:41 PM
