| Anyone know how reliable this Height Control is! Signing a cheque today for a New table and it has Hypertherm Height Control, Hypertherm 1000 g3, Water table, Refurbisher Dell, 1 hp Air Makeup, Mach 3, Viacad, Single Sided Gantry... |
| I went to a demo on this system and the gantry is solid as can be! Double liniar bearings on the Gantry.... Very nice design for loading over sized sheets, and you can load from all three sides. These are well built tables 4x4 table with no gantry is 1000 lbs , plasmacam complete table including the crate is only 385 lbs... When my table arrives I will take some photos and post! |
| I dont think you see what I'm trying to say, and it really does'nt matter whether you do or not. You asked for advice, and I gave. You'll find out what I mean when you see the accuracy in the cut on thin gauge material is not as good as others, and when you start replacing linear bearings because of premature wear. btw...How much a machine can handle is not a function of weight. its a function of design. Ive seen a full 4x8 sheet of 1" on a practical cnc (aluminum frame machine weighs maybe 200lbs? if that) and not do any damage to the structure at all. I've also seen guys throw 1" 4x8 on a multicam 3000 series designed to handle 4" thick plate and actually bend the frame that the slats sit in. |
| Actually I never asked you now it would cut, if you read my origanal post I was wondering if anyone had ever used the hypertherm height control before, but thanks for your advise, what type of cnc table do you own, perhaps you could post a pic of it so I can get a better understanding of what I should spend my money on... Thanks Dennis |
#10
| It's somewhat confusing why the designer of that table would use MACH software for control (one of only two affordable versions of software with embedded THC logic) and then add a $4,500 stand alone THC system. That has to add significantly to the overall cost. So while the argument proceeds about the gantry system the electronics approach gets ignored. Look at the features of the subject Height controller and plug them into my comparison chart for THC fuctionality. Keep in mind that that combination does not take advantage of MACH's embedded THC features (like anti-dive) or automatic pierce delay. http://www.CandCNC.com/THCCompareChart.htm While the transport mechanism and table design is important, over half of the cost and potential areas of problems are glossed over (electronics, software, etc). Hundreds have discovered that a low cost program like SheetCAM has all of the features for plasma cutting you need: Automatic lead-ins/outs, kerf offset, independent pierce height and initial cut height, multiple parts per sheet (part and toolpath step & repeat), and a wide base of users. The light industrial market is evolving and much like the computer market was in the 80's shows the typical technology curve where costs are dropping and designs become obsolete faster. I'm not sure what advantage a cantilever design approach offers since on a drop side table you can just move the gantry out of the way and load from the side or on a conventional gantry table you can end load. We run our production tables with an end feed roller table that allows a single operator to handle larger sheets and just set them on the infeed table and slide a sheet onto the grid. Not having the need or desire to cut thicker material than 3/8" with plasma, everything is setup so the material can come off the truck or storage racks and go onto the table easily. While cutting 1" material with plasma is a possibility you have to invest a lot in a plasma machine big enough to do it so it dosen't resemble something cut with a axe. Plasma cutting works best on thinner sheet materials. At about 3/4" you start to reach a point where Oxy-Fuel cutting is better and cheaper. It's important in the manufacturing process to use the right tool for the job. I don't envy a buyer having to try and navigate the vast number of offerings. Sometimes in frustration buyers focus in on one feature or another (much like selecting a house for the interior paint scheme) for justification. TOM CAUDLE www.CandCNC.com |
#11
I dont have a table...I install them. |
#12
| Torch Height Control | Rxe | CNC Plasma and Waterjet Machines | 7 | 04-07-2010 06:09 AM |
| DIY torch height control | mjp | CNC Plasma and Waterjet Machines | 34 | 12-20-2009 02:57 AM |
| Torch Height Control | luther | Plasma, EDM and other similar machine Project Log | 4 | 07-12-2007 03:51 PM |
| Torch Height Control / Capacitive Height Control | ahlbebuck | Open Source Controller Boards | 0 | 11-27-2006 01:32 PM |
| How important is torch height control? | mm0015 | CNC Plasma and Waterjet Machines | 4 | 08-06-2004 11:19 AM |
