Not sure if this is the correct forum but here goes: As a complete software solution for plasma I see coreldraw -> sheetcam -> mach3 in quite a few threads. However my first confusion is: which coreldraw? I see (on amazon for example) "coreldraw graphics suite" at £38.92 next to "coreldraw x3 graphics suite" at £271.99 - some difference - I assume the former is fine for what’s needed for plasma - is that correct? I'm thinking things like: original (precise) drawing, importing and processing (silhouetting) images etc. Any recommendations gratefully received. Thanks |
| CorelDraw Graphics Suite ver 12 will work fine. The Suite has CorelDraw (vector import & editing) Corel Trace to auto-trace bitmaps to vector and PhotoPaint to use for scanning and image touchup. Has several hundred fonts and lots of vector clipart (not much is usable for CNC because of overlapping vector objects) X3 does not add anything to the basic vector tools you need. Only thing you can say about X3 is that it works with Vista (if you lean that direction!) whereas ver 12 will not allow the service packs to be ap-plied (and you NEED them). |
| Thanks Tom. Anyone else use anything else they'd like to recommend? Wow it's quiet in here - does anyone use anything other than corel? - does anyone use anything at all? does anyone actually do any plasma work? As Pink Floyd sang - is there anyone out there? - talk to me people - you know you want to ![]() ![]() ![]() Ian |
We could go on and on but the final answer would come out the same (:-) |
| Recently a 2008 version has been released & a search will take you to a download location. This software does an excellent job for the original, precise, drawings you require, be they industrial or artistic. Check my project log which has pictures, showing that I "actually do plasma work." |
| Understood Tom. I've already taken quite some time looking for similar questions/answers but frankly havn't come up with much regards "simple" CAD suitable particularly for plasma. The point you make re: solidworks and overkill is really the reason I'm asking the question. For routing I use Rhino/RhinoCAM/Mach - but that would be a similar overkill. (Remember from earlier threads I'm looking at putting together a complete oem solution option) I'm quite happy with the CAM and gcode interpreter/motion control combo of Sheetcam and Mach - I'm also quite happy with the idea of corel - just wanted to know I wasn't missing a similarly priced peach. Ian |
| Looking for new CAD/CAM software, suggestions....? | automan9482 | General CNC (Mill and Lathe) Control Software (NC) | 4 | 01-08-2008 06:48 AM |
| Vertical based cnc plasma comments and suggestions? | Oracle_9 | CNC Plasma and Waterjet Machines | 6 | 06-16-2006 05:54 PM |
| Suggestions for CNC software | AccuDave | Open Source CNC Machine Designs | 1 | 04-13-2006 09:47 PM |
| suggestions for plasma table components | stanglou | General Electronics Discussion | 1 | 11-14-2005 01:18 PM |
| control software suggestions? | daedalus | General CNC (Mill and Lathe) Control Software (NC) | 9 | 09-25-2005 02:29 PM |
