Old 01-20-2008, 03:44 PM
Normsthename is on a distinguished road
Poor quality and Wavy Plasma cuts (Pictures)
Hi
I have had my homebuilt Plasma up and running for a few days now, and I am trying to get to grips with all the different cutting parameters.
I have a Hypertherm 1000 with fresh Finecut consumables and it is using a Campbells THC300 Torch Height Controller.
I definitely have clean air, because by luck I did manage to produce a good cut once......but in my excitement I did'nt note the settings....DOH!
Two problems I am seeing a lot are 'Wavy' cuts and not great cut quality (See Pictures)
The material is 16swg 304 Stainless Steel.
I ran a load of test parts to find the best cutting parameters for the material as follows.
Internal Holes
40amp 47.25" (1200mm) per min at a cut height of 0.25mm
Outside Profile
40amp 138" (3500mm) per min at a cut height of 0.25mm
I am using a homebuilt Water Table, and have the water about 1/2" below the surface of the material.
Would cutting with Nitrogen improve the cut quality, and if so by how much?
Any ideas would be much appreciated.
Andy
ID:	51268   Click image for larger version
ID:	51269   Click image for larger version
Old 01-20-2008, 11:17 PM
Torchhead is on a distinguished road
Those notches are not from using shop air. If the cut gap is staying constant with the THC the nodes are probably from a setting in MACH. Make sure you have the CV enabled and CV Feedrate turned OFF. Watch the torch. If you are seeing ragged movement and hesitation in the cuts then it's a software/setup issue. If tuned right and it should move smoothly through the cuts.
Nothing like starting out on material that is a challenge to cut. Learning your machine by cutting mild steel is a lot cheaper and less frustrating way to optimize the cuts.
Cutting at .25mm? The charts call for .063 inches for cut gap which is closer to 1.5mm.
That's some pretty ugly cuts for a 40A tip.
Old 01-21-2008, 05:10 AM
Thanks Torchhead
I am using Finecut consumables and the book lists 0.010" (0.254mm) for Stainless
I did'nt think there was much use cutting mild Steel when I will be cutting Stainless Steel 99% of the time.
I thought that if I got it cutting good on mild steel, I would then have to start all over again on the Stainless Steel???
I am using Mach3 Version 2.60
CV mode is enabled, but CV feedrate was turned on.
I also read last night that people who use the THC300 with thin material turn off the anti-dive for the THC.
I will try all your suggestions.
Andy
Old 01-21-2008, 07:55 AM
jimcolt is on a distinguished road
It looks like you have either a height issue or an issue with rough motion. Remember that the plasma torch is burning at a fixed power level....whenever the height control makes a correction....expect to see some sort of effect...usually a noticeable notch in the edge of the plate. For the same reason...if there is any roughness in motion...could be mechanical or part program or electronic.....then sudden changes in x and y velocity will create the same effect. If the velocity slows down...the plasma will just burn a wider kerf.
First step in trouble shooting is to dry run through the part program...put your hand on the torch body....do you feel any roughness. If you can feel any roughness during motion...it will show in the cut. If it feels relatively smooth....then do this test again while cutting a part (plasma on, THC on)....if it now feels rougher than before...either quick z axis corrections or velocity changes/mechanical stiction....then you may have to adjust THC sensitivity or you may have issues with electrical noise interference that only ocurr with the plasma on.
Jim Colt
Old 01-21-2008, 08:23 AM
Thanks Jim
I will try your suggestions.
I tried doing a dry run yesterday and touching the torch. It seemed smooth enough to me.
I will try again while it is cutting.
Thanks for the input.
Andy
Old 01-21-2008, 01:18 PM
Well I tried the suggestions, and the cut quality has improved noticeably.
The main culprit seems to be that the CV Acceleration was turned on (Thanks Torchhead )
I still think that there is room for improvement.
I think that the THC may need tuning because it seems to be going up and down many times a second to maintain a constant height (Approx. 5 adjustments a second)
I will post a query on the THC300 forum to see what it should be doing
Andy
Old 01-21-2008, 03:30 PM
In some cases you actually need to detune the THC. Either slow down the z-axis speed or deaden the response. If your machine had superior acceleration/deacceleration characteristics in the x and y directions (there are industrial machines that accelerate at 500 to 1000 mili gees) you can run the THC real hot....but if the THC has a faster feedback loop and faster response time as compared to x and y....it will cause a lot of quick voltage corrections that will show up as notches or pronounce arc lag lines on the cut face.
Some THC systems have asynchronous control...meaning you can adjust the down corrections to be slower than the up corrections. If you think about it...this is a good feature as it minimizes unnecessary corrections that move the torch closer to the plate....while maintaining a very fast up speed to avoid collisions.
Jim Colt
Old 01-21-2008, 04:01 PM
Thanks Jim
I think you are right about my THC
I think it is why the cuts are 'wavy' because the THC is constantly adjusting itself up and down too fast????
There is an adjustment on the Mach3 screen where I can change how sensitive the THC is, I just need to find out which way the adjustment works....
I have read on the THC300 forum about manually setting up the THC first.
You have to turn the THC off and set the material level so the torch can move along at a constant pierce height.
You then do a test cut about 16"-20" long while watching the up & down LED's.
You then adjust the course knob and find the 'Sweet spot' where the LED's are not flickering and the THC is not trying to move the Z axis.
You then turn the THC on and note the position of the knob for future reference, and hopefully that will be that!..........fingers crossed.....
I will try tomorrow and see what happens......
Andy
Old 01-21-2008, 04:06 PM
Mach and the THC300 have a couple of parameters that will help tune the response. The THC300 is an analog control and the loop response time is partially determined by fixed components in the unit.
You can tune the response of the actual THC by raising or lowering the THC Response number in MACH. That determines the reduced speed (percentage of max velocity of Z) that the Z moves will under THC control. A good number is 30%. It depends a lot on your Z speed. You want it set as high as you can (with a leadscrew) then tune the THC rate to make it cut evenly.
The important thing it to watch the tip gap. If it's varying a lot then you need to do the tuning. Just because the Up and DOWN leds flash a lot does not mean the torch will move that often. Another thing to look at is noise. If plasma noise is getting into the tip volts signal back to the THC it will dance around a lot. If your table and plasma unit are not locally grounded (close rod in the earth) then disconnect the earth ground wire on the THC Sensor card. It may be injecting noise into the low side of the tip volts rather than draining it off.
Old 01-21-2008, 04:11 PM
Thanks Torchhead
My machine has stepper motors, and the Z axis uses a 3mm pitch screw.
Its maximum speed is set to 960mm/min
Andy
  #11   Ban this user!
Old 02-05-2008, 09:13 PM
BIGCNC is on a distinguished road
Cool Motion
Just a small note to rule out any problems with motion make a small fixture with a pen that will slide up and down use a rubber band to apply pressure
attach the fixture to the torch, Put a flat steel plate on the table with paper
taped to the steel. And run a program to see what kind of motion you get
I use this to test problems on my machines. Perfect lines= Perfect Parts.
  #12   Ban this user!
Old 02-06-2008, 11:29 AM
Pen tracing is a good way to ensure that the machine has relatively fluid motion and is staying on path....but perfect pen tracings does not necessarily mean perfect cut parts. Here are a few things that will affect a plasma cut part on a cnc machine:
1. Variations in speed/velocity. If the machine is continuously accelerating and de-accelerating...expect the cut edge to appear rough. Plasma requires a rather narrow (too slow/too fast) speed band for each material type and thickness and power level combination......and if the machine does not doo a good job of maintaining the speed even on intricate details....then the cut quality will defiinitely be affected. This is why more pricey cnc plasma machine manufacturers go to great pains to have very high acceleration/de-acceleration capabilities. When the plasma is operated at slower cut speeds...the kerf naturally gets wider...changing part dimensions.
2. Torch height control. If the torch height control system does not accurately maintain torch to work distance within about .005" of the correct height....the the cut edge will be affected in terms of angularity and kerf width. Also...if the THC is overcorrecting...best described as a "sewing machine motion", expect very pronounced lag lines on the cut edge.
3. Occasionally we see issues where with a pen tracing we see very smooth contours...but when the plasma torch is active....the cut edge is very rough. Often the rough edge is dismissed as "that's the way plasma cuts". In reality....roughness during the cut could be an effect of electrical noise interference that is generated by the plasma power supply (many are inverters operating in the 20 khz range) capacitively or inductively coupling to the feedback loop for the servo drives (or stepper drives)....which can cause anomolies with the motion...usually shows up as a rough cut edge. This can usually be felt by resting your hand on the torch body while cutting...if there is any vibration during motion...expect to see it in the cut face.
Jim Colt
tri-power poor quality digitalmdj Shopmaster/Shoptask 12 12-01-2007 06:45 PM
frustration....plasma cuts off during cuts any ideas? gpnjuice CNC Plasma and Waterjet Machines 2 11-18-2007 06:45 PM
Rapid speed between cuts(plasma) C.Michael SheetCam 1 11-18-2007 01:03 AM
Poor cuts, what's going on? cn00728 General Metalwork Discussion 8 10-01-2007 04:43 PM
Pictures of my first cuts with my Torchmate 1 blackhollowmfg Torchmate 15 03-19-2007 12:05 PM
