I was wondering if anybody cut 3/16 AL and special if you use the fine cut kit. Hypertherm does not gives values for cutting with this. I wish I could afford to try test cuts So tips, amps, feed besides what hypertherm gives would be a big help.Thank you |
| The Hypertherm FineCut consumables work quite well on aluminum....although they should be cleaned periodically as aluminum oxide spatter will build up on the face of the nozzle....which can cause short life/poor quality. Follow the specifications for cutting carbon steel...but reduce the speed 25% to 50%....be careful to maintain recommended pierce height and cutting height....try not to drag the nozzle on the plate...and do not exceed the max recommended Amperage! I recommend using the ohmic shield...as this shield extends slightly lower than the nozzle and keeps the nozzle from contacting the plate. You can find the correct part numbers here: http://www.hypertherm.com/languages/english/finecut.php Jim Colt |
| I posted earlier...bu it did not seem to go through.. The Fine Cut consumables will work quite well on aluminum. Follow the specifications for cutting steel....but adjust the speed slower by 25 to 50%. Make sure that your pierce hight and cut height are as recomended for steel.....andI would suggest using the ohmic shield as it helps to keep the nozzle from contacting the aluminum. The nozzle will need to be wiped off periodically as it will pick up aluminum oxide. You can get the part number for the ohmic shield here: http://www.hypertherm.com/languages/english/finecut.php Jim Colt |
| Anybody toubleshoot there Powermax 1000? | tyler774 | CNC Plasma and Waterjet Machines | 4 | 02-25-2007 02:25 PM |
| Hypertherm Powermax G3 not so CNC ready? | Knut | CNC Plasma and Waterjet Machines | 2 | 09-26-2006 10:00 AM |
| Torch Height Control for PowerMax 1000 | barnon | Mach Plasma / Laser | 2 | 08-11-2006 11:30 PM |
| cutmaster 81 vs hypertherm 1000 | dgalaxy | CNC Plasma and Waterjet Machines | 4 | 05-19-2006 08:11 AM |
| THC 300 and hypertherm 1000 | Don C | CNC Plasma and Waterjet Machines | 0 | 10-30-2005 05:33 PM |
