I am in the process of converting my CNC 3 axis machine to Plasma. I have the Campbells Design THC300 arriving very soon, and I am purchasing a Hypertherm 1000 Plasma Cutter ![]() I have seen a few photos of floating head designs, but none of them appear to be spring loaded. Does the torch need to be spring loaded or do you just let gravity do its thing? The microswitch will offer a little bit of spring but not a lot! Also the designs I have seen don't seem to allow the torch to be able to continue on upwards if a fault develops, and the Z axis feels the need to ram the plasma torch into the bed ![]() Is this needed or just overkill? Thanks Andy |
| Spring loading is NOT needed and actually a negative bias spring (canceling out some of the weight of the torch and cables) is needed if you cut thin material. Any downward deflection of the material will throw off your pierce height. If you are paranoid about the Z going to far just mount a second switch above the Z home and make it a limit to stop all movement. I have been running a table with a floating head for over 5 years and I have always been fast enough to stop it from destroying anything during a home (touch-off) move. You just need to keep the slide for the floating head clean and lubricated. Mechanical switches are very reliable. |
| Thanks Torchhead for your input ![]() If the 'floating' head only has to trip the microswitch, it only needs about 1/2" of movement??? The roller microswitch I have bought only has about 3.5mm of travel before it is tripped. I have seen photos of people using 4 1/2" Linear Slide rails for the torch to slide on. Seems like a lot of expense to just give a tiny bit of movement??? Andy |
| DIY spring loaded engraving tool holder | cut more | Engraving Machines | 25 | 12-07-2009 12:34 PM |
| Floating Tap Head - Advice Please | UKRobotics | General Metal Working Machines | 3 | 10-23-2007 08:03 PM |
| spring loaded rack and pinion | dgalaxy | CNC Plasma and Waterjet Machines | 4 | 12-03-2006 11:49 AM |
| Floating Head Switch? | Redline | CNC Plasma and Waterjet Machines | 9 | 09-18-2006 08:21 AM |
| Spring Loaded Rack and Pinion request | ty1295 | CNC Plasma and Waterjet Machines | 1 | 02-07-2005 11:15 PM |
