| is this the one your refering to ? http://news.thomasnet.com/fullstory/13923 we had a couple at a company i worked at before and they worked incredibly well , we did a lot of steel cast and the air and machines stayed clean , as far as cleaning goes i am not too sure as that wasn t part of my dept. ,i don t think they were anything too bothersome . one thing that a guy has to keep in mind is it is necessary to have one designated for steel and another for aluminum , we had a guy quickly light one up when he decided to grind some steel on the aluminum table , it was reduced to maybe being good for roasting a pig at a company bbq |
| I'm generally against water tables due to the high running cost. A typical figure to get a table water pumped and disposed of is about 10 grand. Water does work though... but downdraft is generally a better environment to work in if it's setup correctly. |
| Can I ask what the watertable is intended to do? I assume it captures all the little metal particals and dust generated from a plasma. Why is it so expensive? Does it have a reservoir and filters? I thought they were just pools of water. I'm working on a small plasma project that I would like to be able to run inside my garage. The plasma will stay within a 12" x 12" area so setting up a small water catch underneath isn't that big of a deal. This is loaded question, but what don't I know? And Dertsap, can you elaborate on what happened switching from alum to steel? Thanks |
| luck would have it that the fire dept was there quickly or we would have lost more than just the table |
Here's mine:
__________________ On all equipment there are 2 levers... Lever "A", and Lever F'in "B" |
| I'm currently designing a water table for my 4x4 table. I ended up building a booth around mine and use a big attic fan to vent to the outside. Keeps the shop clean but the machine inside the booth gets real nasty. I am constantly clean the slides and drives. Last edited by barnon; 12-12-2007 at 09:14 PM. |
| Water Circulator for watertable cutting of Aluminum? | Knut | CNC Plasma and Waterjet Machines | 6 | 02-26-2007 12:35 PM |
