Old 11-17-2007, 09:52 PM
gpnjuice is on a distinguished road
frustration....plasma cuts off during cuts any ideas?
Hi Everyone,
I have had a dyna cnc table with mach3 controller up and running for about 4 months. Hi have a thermal dynamics 101. Recently while cutting the torch will shut off. At first it was once in a while, now it will only cut about 2-3 inches and shut off. it is worse on thinner material. Any thoughts? I am sure it is the plasma cutter. I have changed all consumables, checked for water in lines, checked pressure and adjusted amperage settings like a villian but it still is continuing to do it.
the operation manual and the maintainence manual both point to overheating, but it will do it just 30 seconds into being turned on. The fan is working and the kicker is that I can use the hand torch without a single problem....
Do y'all have any thoughts?
Old 11-18-2007, 05:56 PM
xjdubber is on a distinguished road
I know you checked for pressure, but it could be that your losing pressure while cutting.
Old 11-18-2007, 06:45 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Originally Posted by gpnjuice View Post
Hi Everyone,
It might be a bad ground if the work clamp is not attached directly to the workpiece.
The thinner material is often too light weight to pick up proper grounding from the support slats.
which cnc package cuts 2D parts with least extraneous cuts? mbwittig General CNC (Mill and Lathe) Control Software (NC) 3 05-06-2007 06:29 PM
My new TM-1 cuts!!!!!!!!!!!!! blackhollowmfg CNC Plasma and Waterjet Machines 0 03-16-2007 08:24 AM
New plasma cutter ( Even cuts concrete ) ynneb CNC Plasma and Waterjet Machines 17 01-20-2007 01:54 PM
First cuts wcarrothers1 DIY-CNC Router Table Machines 7 10-27-2006 11:17 AM
First cuts no priors General Metalwork Discussion 9 08-21-2006 10:03 AM
